Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is making ice but the ice is becoming solid in the tray and jamming the blades and not comimg out in cubes
  • 1,031 Answers
THE POSSIBLE CAUSES MAY BE FROM THE CUBE SIZE CONTROL
ADJUST THE CUBE SIZE CONTROL
INSPECT THE WATER SUPPLY LINE
TEST THE WATER INLET SWITCH
TEST THE WATER INLET VALVE
Posted on Sep 01, 2008
The ice maker is overfilling enough that the cubes are fused together and there is enough over flow to deposit water in the holding bucket. The ice tray becomes a solid cube.
seems like I read someplace about an adjustment for that problem . check your manual or contact the maker and their tech support
Aug 17, 2015 | Refrigerators
Ice maker tray will not rotate and dump ice. It tries to, but only moves very little. What can I do?
I am a retired service technician. There is a strong possibility that you have a jam. Often ice makers become jammed with cubes that have not dumped. I have also found a plastic sandwich bag that has jammed the ice maker. So, first inspect for a jam.
If there is no jam then the plastic gearing is broken in the motor module.
Hopefully it is just a simple jam.
Oct 26, 2014 | Refrigerators
The ice maker is making a slight clicking noise and not dumping ice. why?
it sound as the tray should be look into. It can be worn out or crackrd
Jul 03, 2014 | Jenn-Air JCD2389G Side by Side...
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
The plastic notched tray of the ice cube maker is broken
Those parts are available and require disassembly of the IM to replace.
Eric
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Frigidare ice maker making slabs of ice, not cubes
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Nov 16, 2008 | Frigidaire Dryers
Ice maker jambed-now no water
The ice maker must be re-primed with water to sense frozen ice in the tray, dump, and refill. Use a cup or glass to manually pour the water into the tray just below the top of the blades. It should freeze, dump, and refill.
May 15, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker
there is a solenoid in the back of the machine that operates that lever on the bottom of the ice bin. make sure that the lever is properly engaged and not stuck jammed etc.
Apr 07, 2008 | Jenn-Air JCD2295HES Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
138 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
