Question about Ruud UBHC Air Conditioner
Ruud a.c. unite
The furnace/ac blower-inside unite will not come on, I hear hum at blower but blower will not start.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Push in on the door safety switch,and use a screwdriver to help start the fan motor, while it calling for fan-on, if it takeoff and run , youll probably need to changeout the fan motor & capicator!
Posted on Sep 01, 2008
I have a ruud achiever 90 plus furnace. The blower motor comes on than I can hear the ingniter click one time and the unit shuts down, 1 green ligt comes on than the other gren light comes on than it...
Check the air filter, if its dirty it will short cycle. A clogged drain will also cause the same problem. There should be a printed legend attached to the inside of the unit or cover that gives you the meaning of all the flashing trouble codes. Perhaps yours may be missing?
Feb 07, 2015 | Ruud Heating & Cooling
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Aug 15, 2013 | Ruud UAKA048 Air Conditioner
Ruud AC unit outside won't start, furnace and blower inside work.
It sounds like your at the point where you need an electrical meter to check out the problem. Make sure you have the proper voltage to the outdoor unit. Could be a bad contactor in the outdoor unit
Mar 01, 2017 | Ruud Heating & Cooling
The unit is not communicating between the Furance and the AC
Then it is not communicating with the thermostat. When you turn it to cooling and the fan comes on, then the thermostat is communicating
with the furnace.
If you have 24volts between Y and C then it is communicating with the AC Unit. If you go outside and remove the electrical panel(shut off power
to outdoor unit) you can still hear the contactor being pulled in.
If you cannot hear that you need a new two wire from furnace to outdoor unit
Jul 16, 2010 | Ruud UAMB024 Air Conditioner
It making a humming sound and the fan is going around slow the temp in home is 74 the set temp is 65 so it should not be running what could be the problem ruud upka-035jak is model
If you are running A.C.,and the T-stat is set at 65,and the room temp is 74,the A.C. will run until the temp goes down to about 65 or so.Turn T-stat to 76 and the unit should shut down. Also,check furnace filter for dirt, and check condensor unit coils and see if they are dirty.If condensor coil is dirty it cannot breathe properly. That will cause the compressor, and the blower motor to overheat.Wash cond. coil down with water hose to clean .Start at top of coil and go sideways,slowly going down.
Feb 23, 2010 | Ruud Matching Split Air Conditioner
You can hear furnace running but the blower never comes on.
do you mean the inside blower or the outside unit blower ... actually the problem might be a similar part in either case ... the blower motor has a capacitor mounted on it or near it ... it will be marked something like 160 uf at 200vac or similar . it will have wires attached or plugged into it .. the capacitor is what gives the blower motor a signal to tell it which way to start turning ... once the blower is running then the capacitor is no longer needed ... its only used to get the motor started ... if its bad then the motor will hum but wont turn .. if you manually spin the fan then the motor will take off in the direction you spun it (dont get hit ) .. a new capacitor is not expensive .. you need the numbers off the old "starting" capacitor or just take it with you to the parts place to match it up .. you may be able to order it from Ruud ... a HVAC repair person would likely be able to bring one with him for repair if you give him the numbers off the part or the model number of the furnace .. make sure the blower turns freely by hand (with power off) .. if not it may need bearings lubed .. ..
Nov 05, 2009 | Ruud Central System Air Conditioner
Blower fan wont shut off
Try cycling the switch at the furnace to reset the blower board. If this doesn't work remove the green wire from the blower board(computer board) to eliminate a shorted t-stat or shorted wire between the furance and t-stat. If blower remains on, then blower board is shorted. I've seen all these problems.
May 04, 2009 | Heating & Cooling
Ho to turn on central AC unit? (Ruud High Efficiency)
This is typical wiring for a 4 wire thermostat
R = Red One Side of 24 volt Transformer
G = Green Blower relay
Y = Yellow Cool Condensing unit
W = White Heat Furnace
Apr 28, 2009 | Ruud Heating & Cooling
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
321 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
