Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
My dyson is making a loud horrible noise
What do I do?
  • corwot Nov 12, 2008
    roller brush does not rotate how do i check roller correct position
  • cafeteaorme Nov 12, 2008
    I have the same problem. Horrible loud vibration only when the roller is engaged. I took off the panel and cleaned off the roller only to find the noise got ten times louder. any suggestions????
  • 372 Answers
Hi.
Check the brush roller can be moved by hand & that it is not snagging on something.
If it is difficult to rotate remove sole plate by turning the 3 plastic screws to unlock position lift plate off & clean brush roller & check you can turn it after this.
If brush roller is free to rotate the chances are the clutch is faulty & will need to be replaced.
Go to this site http://dysonmanuals.llc.nu/
It has manuals that cover clutch replacing on all Dyson models.
Posted on Sep 01, 2008
5 Suggested Answers
  • 83 Answers
SOURCE: he dyson is making a very loud grinding noise
The belt that rotates the beater bar may be damaged - call the Dyson helpline for troubleshooting and for a solution to the problem.
Posted on Jul 30, 2009
SOURCE: why does my Dyson animal
I can't probably help you but I can tell you what Dyson told me. I have this same vacuum and it just started making that same noise. When I called their rep they had me take off the bottom plastic piece (comes off real easy by taking a coin and turning the three circles). Check to make sure the belt isn't broke. Then, they had me pull toward me the roller brush and turn it to get it seperated from the belt. Then, take off the belt. On mine, the spindle was full of dog hair clogging it. I took twizers and narrow pliers and pulled everything off. Then put it back together. It worked fine for the next few times I vacuumed then it started again. So, I did the same thing again and found this spindle covered with the hair again. Cleaned it, put it back together and it worked again. Today, while vacuuming I picked up a piece of string and that noised started again. Turned it over and saw that string on that spindle. Took it off, cleaned it and it worked again then started the screeching again. So, tomorrow I am calling a vacuum repair place. IF you have the same vacuum (which you do) it should still be under warranty. Dyson told me I would have nothing to pay unless I abused the vacuum which I did not. Hopefully I am not without it very long...I have two golden retrievers who do shed alot.
Posted on Nov 27, 2010
  • 4088 Answers
SOURCE: My dyson D17 is making an incredibly loud noise,
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Posted on Aug 02, 2009
  • 143 Answers
SOURCE: Hello. My dyson dc04 keeps making a loud screeching noise.
remove base cover by 3 'screws' 1/2 turn anti clockwise and clean well remove fibres replace cover and re try.
Posted on Sep 14, 2009
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My husband ran over my daughters shirt with our Dyson DC17 animal. Now it's making this horrible load ratting noise. I've taken the head off. Clean the beater bar. The belt is in tact. No
First make sure there are not any of the rubber cogs missing from the belt, it may be wise to replace the belt anyway because the cogs may be worn. Make sure the brush roll does not have any play in it anywhere and that It fits tightly in the nozzle housing without any play. If there is any play or wiggle that will cause it to move.
Apr 21, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
He dyson is making a very loud grinding noise
Jul 03, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I ran over a shoe lace and now it is making a loud rattling noise
The All Floors model has a protective belt clutch system and the rattling sound means the clutch has slipped. This would have to be repaired officially by a Dyson repairer.
Jun 15, 2009 | Dyson DC07 All Floors Bagless Upright...
Brush bar does not turn & makes a loud noise
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
May 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The beater bar makes a horrible clunking noise when I turn it on
I just came from the repair shop. There is a recurring problem with a bearing coming out. Repair guy turned it on & said that loud noise is a symptom of that exact problem. This is a warranty item, as is the belt & on/off switch. Dyson comes with a 5 year warranty, so call their 800 number to get the name & address of an authorized repair shop.
Jun 08, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Trouble with Dyson
Hi i had this problem myself and it sounds like your clutch assembly is broken which would be what the horrible noise your dyson is making only when your brushroll is on. Go to www.sparesaver.com to the help & support section.
It tells you all the information you need to know on how to Fit and take out your clutch and they supply it at a fantastic price!
Andrew
Mar 18, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Nov 11, 2007 | Dyson DC14 Full Access Bagless Upright...
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
Oct 14, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
3,123 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
