Question about Technics SL-1200MK2 Turntable
What cartridge do I buy for this turntable
I bought the turntable and went to assemble it -=but it doesn't include a cartridge. What cartridge goes with this turntable and where can I buy it? thanks from paulao in nyc
  • 3 Answers
You should get a headshell first of all. Into the headshell you install the cartridge. I would get a Technics headshell just because it is of the same brand, and I use a SHURE M35X cartridge which is mean for dance or electro music. The headshell is your option but the cartridge should be matched up to what type of music you will be playing. Good Luck
Posted on Sep 01, 2008
Just got this used turntable. It's in great shape. Hook it up but it isn't amplified loud enough. I have no ground wire. Help
Turntables, especially older ones, typically do not have preamplifler circuits, which are necessary to bring the output signal from the pickup cartridge to "line input" level for modern amplifiers. You will either need to buy a PHONO PREAMP unit (goes between the output of the turntable and the input of your receiver), or get an older receiver with a (MAGNETIC) PHONO input (internal magnetic cartridge preamplifier).
May 09, 2015 | Audio Players & Recorders
Cartridge dragging
Check that the cartridge is fitted properly.
Jan 13, 2013 | Audio Technica ATLP120USB Turntable
Need to buy a turntable for my husband this week. I am overwhelmed with customer reviews and need an expert to advice me. My budget is 800 including cartridge. I am looking for great sound, but someone...
If poppa has a clue about audio he'll know how to digitize any source he has into the laptop. You shouldn't necessarily try to get that capability built-in to just one component. What about the rest of them? That function should be higher up the audio foodchain.
Whatever you buy make sure your existing electronics can support it.
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your electronics doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
I'm partial to Dual (the brand) turntables but maybe hubby wants something that has USB for direct PC attachment. Modern TT's made for ripping LP's put more into the ripping than the 'turning' and 'tracking' and usually lack heavy platters for speed stability, fine tonearms with adjustments and better phono cartridges/sytlus for maximum capture of the information in the groove with minimum damage for optimized playback. You need to do some intelligence gathering to see what he wants and needs.
$800 will get a lot of turntable.
Aug 09, 2011 | Audio Players & Recorders
I recently bought this turntable used. I am trying to connect it to a Sony receiver with a phono input, but no sound comes out when connected. Does this turntable require a pre-amp or something?
If the unspecified Sony has a "PHONO" input you should be good to go. What model?
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
Jul 27, 2011 | Panasonic Technics SL-1210MK2 Turntable
My turntable does not have good sound? Is it the stylus needle?
It could be, first check all connections as they can come loose. It could also be the cartridge, the only way to find out is to get a new one. If you get a cartridge and stylus, you can fit the new stylus to your old one, if that solves the problem, you have a spare cartridge in stock, if it doesn't then replace the cartridge. If that doesn't work and the connections are good, then there is a fault on the magnetic cartridge pre-amp in your amp.
Jul 14, 2011 | Sony PS-LX300USB Turntable
I replaced the stylus with needle and now when i try to play a record, it makes a terrible crackling noise and the record sounds completely blown out. just bought a new tuner preamp too, so its probably...
Unplug everthing. Reseat all connectors, Did you replace the cartridge when you replaced the stylus? If so, verify that the 4 tiny tiny wires and connectors are on tight. Also, some of these turntables have a 'knob' built into the tonearm that you need to twist to release/lock the whole head assembly of the tone arm. Try to see if you have a removable tonearm cartridge assembly and then twist this tight. It sound like its in the wiring from the cartridge to the connectors to your preamp. The levels are so low, that any loose connection will be amplified 100 times.
Aug 10, 2010 | Sony PS-LX300USB Turntable
I have a Crosley 6005a. In turntable mode - sound is tinny and needs to be turned way up to hear it and it is not in stereo. Is this just the way it is or can I fix it. I bought it second hand
Check all conections to the turntable, also I think you should buy a new cartridge as a matter of course. I rather suspect it's (the cartridge) either **** or gone!
Jun 06, 2010 | Crosley 0187SST Turntable
I just assembled my numark ttxusb turntable but the stylus was not included
Go back to the dealer you bought the deck from. He is responsible for providing a stylus and fitting it for you.
Jan 18, 2009 | Numark ttUSB Turntable
SONY PS LX300H turntable works only one channel at a time
This sounds suspiciously like the wiring of the cartridge is wrong or something is shorted together. The cause should be visible.
Taking special care to NOT touch the stylus itself in this operation:
Turn the locking collar and remove the cartridge assembly in its shell from the tonearm.
Flip the assembly over and examine the four wires under a magnifying glass for disconnections, kinks, crimps, or metal-to-metal contact between any of them. They should each attach to a pin exiting straight out from the cartridge.
The wires are also color coded as are the terminals. If they're wrong you could have various sonic malfunctions.
Correcting miswires is delicate and I would recommend taking the turntable and stylus to a pro for that part.
Dec 17, 2008 | Sony PS-LX250H Turntable
Technics SL-1200MK2 Turntable Logo
283 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
