Printers
Problem for Printers
Generic problem for all Printers
Samsung ml-1740 printer - their driver not...
By richsouth on Sep 01, 2008
Please help me.
I have downloaded the printer driver from Samsung, and it says it is not compatible with my Windows OS system. I have a new 64 bit Toshiba Satellite M305-4830 laptop.
I've tried installing the Ml-1750 driver to see if that would work but it doesn't either.
How could I get my printer to work?
I would be thrilled if you could help me.
Richard
richsouth@juno.com
Same Problem
Sep 17, 2008
-   Windows Vista 64 Bit will not work with Samsung ML 1740. I downloaded the appropriate driver from Samsung, and vista says that it is not compatible. How can I work around this?-   battus
Sep 09, 2008
-   Same problem. Samsung ML 1740 and 64 bit Vista-   gmortaloni
Sep 03, 2008
-   I have the same 64-bit problem. Would love input that could keep me from spending $100 on a new laser printer. -   worstbdate
Solution #1
posted on Sep 21, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I found a solution quite by accident. I had downloaded the latest Samsung driver to a flash drive and then copied it to the "C" drive of the new computer. Every attempt to open and run it failed due to alleged incompatibility. I then opened control panel and selected printers. I deleted the samsung printer and then ran the driver directly from the flash drive. Voila! It worked! It is now up and running perfectly.
Battus
Solution #2
posted on Jun 11, 2009
Very Helpful)
kenwong1
Rank: Apprentice
Rating: 100%, 1 votes
Samsung has a Universal Print Driver (XP/Vista/32 or 64 bits) which worked for me. I installed it my 64 Bit Vista Laptop and was able to print via USB. Then I installed it on my XP desktop and made the printer shareable. I was then able to disconnect the USB and install the network printer.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jan 10, 2009
Very Helpful)
tomobob
Rank: Apprentice
Grab the GDI variation of the Vista driver posted in later December. Seems to work!
Was this helpful?
Yes
No
Solution #4
posted on Nov 12, 2008
Very Helpful)
ramys
Rank: Apprentice
you must go to printer in control panel, then right click the desired printer icon, then click properties, then click on Port. then if using usb port, you must check each port untill you find the correct usb port that you are connected to (click apply each time). may take a couple tries untill you find the correct usb Port that the cable is connected to. worked on my HP desktop, finally
Was this helpful?
Yes
No
Solution #5
posted on Aug 22, 2009
Not Rated)
mdbeatle
Rank: Apprentice
Rating: 0%, 0 votes
I used the ML-1740 driver for XP x64. Extract the contents of the driver executable you download from Samsung, then manually add your printer and point to the WINXP_64 folder from the extracted folders. I did this on Server 2008 x64 but it should apply to Vista x64 as well.
Was this helpful?
Yes
No
Solution #6
posted on Nov 16, 2008
Not Rated)
cyndod
Rank: Apprentice
Rating: 0%, 0 votes
though i've tried installing my ML-1740 with its original disk and with the latest vista driver that samsung provides online, no printer icon is visible in the "printer" section of the control panel for me to click on to select a port. can anyone tell me, step-by-step, how they've gotten their printer working with windows vista 64 bit? thank you!
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
Is c4200 stil availabl eto buy?
Answer
MP 620 printer is it a good buy
Answer
my mp 170 display "check ink" u051 BLK COL
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
