Question about Clarion DXZ838RMP CD Player
A week ago, the cd player stopped working and Error 6 was displayed in the screen. The disc is properly inserted and the only think I can think of is that 2 weeks ago the battery of the car died because an electric problem, so I fixed the problem and recharged the battery, but the player continued working normally for a week or so, then this I am telling you, even with original cd's.
I will try with a cd cleaner, but do you think it could be some kind of electric problem?
What can I do?
  • David Jano Sep 01, 2008
    I tried with a cd cleaner, but still the same problem.
    I also tried reseting the unit and even disconecting the car battery, but it was all the same.
    If I want to clean the lens, could you please guide me through? The slot is as wide as a cd, so I cannot get to the lens from the front of the unit.
    Thanks for your answer!
    Problem Solver:
  • 12 Answers
Here is the link to the user manual for your player if you need it;
http://www.clarion.com/gb/en/MungoBlobs/...
Page 38 of the manual (page 42 of the pdf file) describes the error codes
error 6 states "a disk is loaded upside down inside the cd deck and doesnt play properly"
Suggested solution is to try the disc the other way up, if this doesn't help then there is most likely a problem with the lens - possibly cured by cleaning, please ask again if you want to try this yourself and we can talk you through it
pls - check also that the cds you where trying to play were of the correct type, and burned in the correct format, also that the settings are correct for the type you are using - page 21 (25 pdf)
Next thing to try is cleaning the lens - use a cotton bud which you have dipped in alcohol - rubbing alcohol is ok - but let the cotton bud dry mostly before going at the lens.
Figure out how to get to the lens and very gently wipe it with the cotton bud.
Remember the lens is not that scratch resistant, and it is quite finely positioned, so wipe, dont scrub.
If that doesnt help, then check that there is adequate voltage to the unit - it may have enough to appear to function but not to initiate the laser - bad ground cable would be the first suspect.
If no luck with that, then i think the set needs to be serviced properly - sorry
if you need help finding a service centre let me know with your general area
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 01, 2008
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
When i put a cd in my DRX7575z cd player it comes up with error 6 i have radio function but no cd
Error 6 means your laser isn't reading disc. Needs replaced pick up laser. I would try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist, you have to go to fix it to a specialist.
Sep 23, 2009 | Clarion DRX7575z CD Player
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Car MP3 player error
I believe that error 6 means incompatable disc format or disc read error.
Jun 12, 2008 | Clarion Car Audio & Video
Clarion DB175 cd player
The Clarion manual lists 3 error messages.
Error 2-A disk is caught inside the CD deck and is not ejected.
Error 3-A disk cannot be played due to scratches, etc.
Error 6-A disc is loaded upside-down and cannot be played.
Good Luck.
Mar 26, 2008 | Clarion DB175MP CD Player
Message of an Error
error 6 means that a disc is loaded upside down.
eject the disk and reload it properly
if that isnt working, your CD player is mal-functioning and you should consult Clarion for help
J
Mar 12, 2008 | Clarion DXZ845MC CD Player
Clarion DXZ838RMP Installation guide
here's the insatllation guide; http://www.clarion.com/gb/en/MungoBlobs/423/180/DXZ838RMP-EU.pdf It is very detailed and has i think all the wiring info you would need :)
Apr 15, 2007 | Clarion DXZ838RMP CD Player
Error 6 on in car stereo
Here is the link to the user manual for your player if you need it; http://www.clarion.com/gb/en/MungoBlobs/483/874/DXZ838RMP-EU.pdf Page 38 of the manual (page 42 of the pdf file) describes the error codes error 6 states "a disk is loaded upside down inside the cd deck and doesnt play properly" Suggested solution is to try the disc the other way up, if this doesn't help then there is most likely a problem with the lens - possibly cured by cleaning, please ask again if you want to try this yourself and we can talk you through it Hope this helps :)
Clarion DXZ838RMP CD Player Logo
304 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
