Question about NAD 533 Turntable
NAD 533 Turntable
The drive belt appears to be streched - new one needed. Where are they available ?
  • 515 Answers
Just do a search in Google for "NAD 533 Drive Belt"
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
How do I set-up my NAD 533 turntable for initial use???
This Turntable looks nice. The belt goes around the two spindles [one big one small. the speed is adjusted by choosing which part of the small spindle you put the belt on. The upper platter rests on the big spindle and doesn't seem to be secured to it.
The counterweight should simply screw onto the back of the arm.
Manual can be found here: http://akdatabase.org/AKview/albums/userpics/10007/NAD%20533%20Turntable%20Owner's%20Manual.pdf
Jul 02, 2014 | NAD 533 Turntable
How do I set-up my NAD 533 for it's first time use ???
nadelectronics.com/products/turntables/533-Turntable
www.manualslib.com > Brands > NAD Manuals > Turntable > 533
Jul 02, 2014 | Denon DP-29F Turntable
Where can i get a on/off switch for a NAD 5120 turntable?
You will have to match it up to something that's currently available, as NAD is long out of business. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 06, 2013 | NAD 533 Turntable
Grating noise when turntable is spinning
if u r comfortable taking the turntable off the record player do that and turn on the player without it on see if the grating noise is still there if it is u have a motor problem if it is gone find out from a stereo place what u can use to clean the top, bottom edge, and underside of the plate that the record sits on check your belt for signs of wear good luck
Sep 30, 2013 | NAD 533 Turntable
Forgive me for not knowing what any of these parts are really called. My friend just shipped me an NAD 533 turntable & when I received it the cover was cracked and the hinges broken, the round weight...
My suggestion to you, if you really need a turntable is to find one at a flea market, since the ones you currently find in the market are "professional" quality, and are very expensive. The same applies to the stylus (needle). The reason they give you when you ask why: They are somewhat of an oddity nowadays, after CDs, DVDs, and now Bluray!
Dec 02, 2009 | NAD 533 Turntable
Loss of turntable speed - is it the motor and can it be replaced? Platter still rotates but belt struggles to turn it - capstan appears to be loose.
Yo wil need to check your belt tension and if it is worn. If so it will need to be replaced. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Aug 17, 2009 | NAD 533 Turntable
Streched CD drive belt
turntableneedles.com has about 450 belt sizes in stock. your unit is too new to have this listing yet as the belt should not have failed already so when you call be ready with the length of the old belt. Don't worry that it is stretched, a new size will be calculated that is about 3-5% shorter.
Jan 13, 2009 | Philco 841205 Turntable
Problem with connectors, no left channel
Your RCA leads/cables might be bad and need to be replaced.
- OPTiC
www.1200s.com
Aug 23, 2008 | NAD 533 Turntable
Nad turntable
the belt (aka rubber band) should be changed when it starts to slip
it is not whats causing the table to turn backwards. it's the motor or circut that drives the motor.
Jan 22, 2008 | NAD 533 Turntable
NAD 533 Turntable Logo
235 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
