Question about Kenmore 54701 Dehumidifier
Kenmore Dehumidifier Your solution to the kenmore dehumidifier fan not running is the perfect low cost repair. I have two of the 70-pint units. The first one quit working with this problem last year so I bought another new one. Yesterday it quit so I was looking at buying another one of some other brand when I happened up on your repair solution. After reading your solution, I went to Radio Shack and purchased two of the thermal fuses for $1.69 each. I took all the the panels off the first one, got to the fan motor, cut open the sealing tape and replaced the fuse. Put it all back together and now it works like new. On the second one instead of taking off all the panels I just took off the back, reached in and removed the fan and fan motor and made the repair without taking off the other panels. I did find one thing that you didn't mention that should be of additional value to others with this problem. What I found as the cause for the fuse blowing was rust on the inside of both motors on the armature & frame which had prevented the fan from turning freely. I cleaned the rust away with sandpaper and small wire brush. I suppose the rust develops due to the humid air that is pulled through the unit by the fan. Thanks for posting your solution. For $4.00 and a couple hours time I now have two units that are working like new. Whole lot better than buying another new one!!! Thanks......
  • LTBONRYE561 May 01, 2009
    THANKS FOR THE INFO . HAD THE SAME PROBLEM. AM HEADE TO RADIO SHACK.
    ONE QUESTION: WHY DIDN"T YOU SPRAY THE MOTOR FRAME AND ARMATURE WITH SOME WD 40?
I wonder if a little squirt of WD40 would go a long way in preventing the rust problem?
Posted on Oct 27, 2008
Kenmore 407 50 pint dehumidifier won't drain through hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Oct 13, 2012 | Kenmore 90701 70 Pint Dehumidifier With...
I have a whirlpool dehumidifier 70 pint and the fan runs but no longer collection of water...we have had it about 4 years.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Oct 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Kenmore Elite 70 pint unit. Compressor appears to be frozen. Fan runs and compressor attempts to engage but immediately shuts down. Any suggestions. Unit is only about 2 years old.
Hi, I think you got it figured out...
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | Kenmore 54501 Dehumidifier
My kenmore 70 pint dehumidifier turns on but will run for two to three minutes and then it turns itself off. Is there a sensor that would have stopped working? My email is mkemusic@sunlink.net
heatman101
Aug 24, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier freezes up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Jul 01, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have 2 kenmore 70 pint dehumidifiers. Neither one is collecting water in the pan when running (therefore neither is running). Is there a reset button?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Feb 17, 2010 | Kenmore 54701 Dehumidifier
I have a Kenmore 580.53701300 dehumidifier (70
Jim,
I have this dehumidifier and the owner's and parts manuals to go with it.
I will scan them and email them to you.
Hope this helps!
Jamie
Jul 31, 2009 | Kenmore 53701 Dehumidifier
KENMORE 70 PINT DEHUMIDIFIER
4681A20040R is the fan part #. Bought one on e-bay. Fixed the same problem.
Aug 18, 2008 | Kenmore 54701 Dehumidifier
Kenmore 54701 (70 pint) dehumidifier stopped running
the lowest setting for % of humidity is 35% on that unit... sounds like with all the other errors that the IC board is bad (the Control circuit board behind the displays)
Nov 25, 2007 | Kenmore 54701 Dehumidifier
Kenmore 54701 Dehumidifier Logo
516 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
