My hard drive is not playing the game i put in it
    Champion:
    Scholar:
  • 209 Answers
Go in Windows Explorer, locate your CD-ROM drive (D: or E:). Right-click on it and select Automatic run.
Posted on Sep 01, 2008
When putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the...
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
Jul 18, 2011 | Microsoft Xbox 360 Console
Tip
How to play a scratched disc on xbox 360 or some other consoles
Note: I have only experienced using this trick on the XBox 360 Console.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
on Jan 23, 2010 | Video Game Consoles & Games
My Xbox 360 keeps saying "The Disc is Unreadible"
put the disc in the drive and go to game library. then select game and save to hard drive. this will back up your game. takes 10 mins approx. then play game from hard drive. daniel_james5@hotmail.com
Feb 21, 2010 | Microsoft Xbox 360 Console
5 minutes playing online keep giving me error message that the disk is dirty. i know it's not i played the same cd to another xbox console it's fine. what should i do or what's the problem...
Hi chrisastig
try to save the game you are playing to the hard drive so as to play from hard drive & not from the disk ! this is assuming you have enuf room on ur hard drive to copy the game to ??
You will still need to put the game in (even when playing from hard drive) but i find if its a game you play a lot its well worth doing as it saves on the disc drive/disc spinning whilst playing :-)
saves on overall usage of the xbox too !
If its ok reading the disc for the first 5 mins of usage it should be ok to copy to the hard drive to play from.
If there is a fault with the disc itself it will tell you when you try to copy it to the hard drive & if this is the case (& its a game you like/play a lot??) then try to borrow a copy just to put on ur hard drive only & use ur damaged disc as the 'required even if playing from hard drive' notification to the xbox that you do own the original copy !
Damaged discs are usually ok for 'playing from hard drive' as the information the xbox requires is very little but enuf for it to allow you to play the game (from the hard drive)
You will find it a lot quieter whilst playing anyway ! i think so !
hope this helps :-)
please remember thumbs up :-)
p.s. refer to ur xbox user manual or drop me a mail if you have any problems doing any of the above ??
Feb 14, 2010 | Microsoft Xbox 360 Console
Can't upload a CD on my xbox
If you have the (fall update), you should have that option. When you put a game in make sure it isn't on auto-play. Under the play game box, the option to download to hard drive is the Y button.To burn normal music CD to your hard drive you will have to go to music, then current disc. There is no option for downloading an MP3 disc though.The console will only play MP3's. I hope this helps you friend.
Jan 31, 2010 | Microsoft Xbox 360 Console
Won't play games. e hard drive does not seem to be reading the harddrive
Try another hard drive in the system and do a quick format thru the menu in the ps3. Once it goes thru that. Put a game in and see if the game plays and saves the information to the hard drive properly.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
I have games downloaded on my pc that I got from free game sites. They are legal games that are free because they are sponsored. I would like to take them off of my hard drive and put them on cds to free...
Only if they are designed to be run from CD. Most games are "installed" onto your hard drive and put files all over the drive, not just in their game folder. So copying them from their game folder to a CD may lose support files needed to play. Easiest way to try this out...copy the files to the CD, then delete the files from the hard drive. Then try to play the game. If it won't play, copy the files back to where they were on the hard drive.
Sep 15, 2009 | Dell Dimension 3100 PC Desktop
How to play xbox 360 images off the hard drive?
You need to keep in the disc you can never put out the disc and play the game.
Sep 11, 2009 | Microsoft Xbox 360 Console
Won't recognize and load games, only DVD's.
hey problem is the drive key on your dvddrive doesn't match the new m/board you put in...??
you need to get the drive key off the new m/boards original drive and flash it tot your driv.... each m/board has a matching key on there dvd drive.
Jul 27, 2009 | Microsoft Xbox 360 Console
Cant play games
The pro and premium motherboards take the 20 and 60gig HDD they can not handle a 120gig. Have him try to play a game with out any hard drive attached and see if it works. If it works have him put on his original drive with the console on then turn it off. Unplug the power cord and then turn it back on. Good luck,
Jul 19, 2009 | Microsoft Xbox 360 Console
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
