Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dishwasher not working
When I press the start button the "washing" light illuminates but the machine does nothing.
  • aspenstu Sep 10, 2008
    My dishwasher is only a little over a year old. It just suddenly stopped working. The light just flashes but nothing happens. I have tried to reset it but it does nothing
    Sergeant:
  • 409 Answers
Can you give me the exact model # on your d/w? i need to see if it' has a timer or an LCD.
Posted on Sep 13, 2008
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
My kenmore ultra wash instaled dishwasher wont work. The "lock on" light is illuminated and when i press any button the lock on light just flashes 3 times. i tried pressing buttons, holding the...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank You for using Fixya
Sep 16, 2011 | Kenmore 15129 Built-in Dishwasher
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Whirlpool dishwasher
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore 16039 - "Clean" light is flashing & dishwasher won't start
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
Jun 15, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
74 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
