Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
Uneven Color on JVC Projection TV
Dear Sirs:
The color is uneven with a two foot diameter (approx) center area creating a greenish hue in the middle with slight purpleish around the edges miscoloration effect. Swimming pools look green.
I would like to hear that I can open this thing up and turn a screw...and that I can do it easily....and it will be worth it.....
Hello i have a jvc 52" made in july 2004 replaced bulb twice under warranty plus replaced ballast board in 2005 replaced bulb dec 2008 my tv was before and after install having a blue hue reversed words
Posted on Jan 12, 2009
JVC HD 56FN97 No RED color
Does menu have any red? Yes = digital video bad; No is light engine bad.
Mar 31, 2014 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
Kp57hw40 is a greenish color
If green appears to bleed out of objects then it's probably the saturation level is to high. If that doesn't work you can try changing the Hue setting more towards red and away from green.
If neither works and you don't have a warranty I would call your a local TV repair company.
Oct 22, 2012 | Sony KP-57HW40 57" Rear Projection...
Uneven or blotchy color
ur internal components have degraded due to continuous usage
Jan 13, 2010 | Televison & Video
JVC HD-52Z575 TV that has briteness an color purity problems.
From what little I have read about these TVs parts are High Call JVC 1-800-233-1060 Ask for TECH surrport them them what your problem is If it doe turn out to be Light engine Call UED for price of rebuilt one 1-800-648-6657 Also go to website ENCOMPASS look up your Model number they will have a listing of Parts 1-800-638-3328 You can try Downloading to USB stick in formation to it reprogram eeprom to TV sometime this will correct problem! GOOD LUCK with the repair.JVC downloads.
Oct 01, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Picture mostly green
In that case does this color problem occur on all inputs? If not then please make sure that the connections, especially the red connector, are clean and tight
Mar 16, 2009 | JVC AV-27D303 27" TV
RCA DLP TV with a red dot in the middle of the screen
Sounds like the color wheel stopped and re-started. It may continue to function for a while, but could fail at any time.
I've also seen on rare occasion, a defect in a lamp produce uneven color rendition, but its far more likely that the culprit is the color wheel.
michtech
Feb 13, 2009 | RCA D52W19 52" Rear Projection Television
Big vertical tinted stripe on screen
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Dec 12, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
338 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
