Question about Kenmore Elite 45986 Front Load Washer
Kenmore front load washer door
The door on my front load washer is open but the lock mechanism is still locked. The door will not close all way because the lock is functioning. How can I get the door unlocked so I can close the door and get the washer running again?
  • 5,911 Answers
A lot of these errors on these front loaders can be resolved by simply unplugging the washer for 30 minutes to reset the computer. You may also attempt to manipulate the door latch by using the manual release lever to see if you can get the latching mechanism to stay open. The following link explains how to do this:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This is normally used when the door is latched with the door shut, but it still may apply in your case. If you attempt any of these preliminary checks and the latch still does not work properly, I would recommend replacing it. The next link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Hopefully you will not require any replacement parts. But, if you do, a replacement latch can be found at searspartsdirect.com or repairclinic.com. Just type in your complete model number to perform a search for parts. I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 01, 2008
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
During spin cycle, load was out of balance, now cant get the door to close. Lock mechanism is closed. How do I get the lock mechanism to open and allow the door to shut?
You can attempt to reset the operating system of your washing machine by unplugging it from the outlet and leaving it for a few minutes and then replugging it.
Dec 28, 2010 | Kenmore HE2 Plus Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer shows door not locked but the door is locked and will not unlock. it will not start either.
Try pressing 'end of cycle' for 3 seconds. You hear a click? Then wait for 2 minutes before trying the door, do not force door. No luck? Plug off the mains. Tilt machine backwards to unscrew 3 screws below the front panel, the kick panel. Slide the panel downwards & out.
Put your hand up towards the lock portion (inside the machine that is), you will feel a tear shaped thing, pull this thing a quarter of an inch down, the door will click open. Check to see that all wires are connected well.
Next try some WD40 on the door mechanism on machine, not on door, & try the door open/close a few times. Would be nice to know what happened............free service remember.(!)
Mar 09, 2009 | Kenmore Elite 45986 Front Load Washer
Washer wont engage
The door may not have been fully closed. stop/clear cancel the cycle. ensure door is fully closed and attempt to resart cycle.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Feb 08, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
138 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
