Question about Dell Precision Workstation 670 PC Desktop
Dell Precision 670 throws "BIOS not installed!" message
Hi, I just bought this Dell Precision 670, and after starting, it displays the hard drive: SCSI 73GB, but then renders "No logical drives found" and then "BIOS not installed!" I am unable to understand what went wrong, or if the BIOS is really damaged. I don't know how the BIOS could not be installed because I can go into the setup and change settings as I like. Please help. Thanks.
  • Anonymous Dec 10, 2008
    yes
You need to enable the scsi in bios.
Posted on Sep 23, 2009
    President:
  • 2,961 Answers
I think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Posted on Sep 01, 2008
The "BIOS not installed"refers to the SCSI adapter's BIOS, not the system BIOS. It does not install because the hard drive is empty. Access the host adapter's setup program and create logical drives.
Posted on Sep 29, 2008
Hi, I just bought this Dell Precision 670,and it shows: "No logical drives found" and then "BIOS not installed!" I am unable to understand what went wrong, or if the BIOS is really damaged. I don't know...
Power on computer and enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
Aug 11, 2013 | Dell Precision Workstation 670 PC Desktop
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
Dell Precision 670 RAID1 Install on Windows 7
The RAID configuration maybe setup in the BIOS settings.
Mar 31, 2012 | Dell Precision Workstation 670 PC Desktop
Computer wont find hard drive to reboot dell percision 670 not sure what settings to have on in bios
go bios press by f 2 or f 1 >change the boot sequence >first boot cd rom >2nd boot hdd.
ensure that *********** has recocknise the hdd if not ,should change the cable for hdd.Or can fit it tightly.you can see the hdd from driver configaration.
think it will you
Nov 24, 2010 | Dell Precision Workstation 670 PC Desktop
Bios update for Dell Precision workstation 670 & instructions?
DONT EVER UPDATE BIOS....99.99% IT WILL MAKE UR PC A DUD....MFGS DONT MAKE NEW UPDATES FOR OLD BIOS...AS BIOS CHIPS ARE HARDWARE MFG SPECIFIC...IF U STILL WANT TO DO...U NEED TO BE 1000000% SURE OF WHAT BIOS IS IN UR MACHINE AND WHAT BIOS SOFTWARE IS INSIDE THAT.....EVEN I AS AN EXPERT DONT ATEMPT IT....AS ANY CHANGE TO BIOS IS DIFFICULT TO REVERSE....
writing in all caps amounts to shouting....
sorry i wrote it in capital....not ment to shout at u...
just warning u
Sep 26, 2010 | Dell Precision Workstation 670 PC Desktop
Precision 670 crash during bios upgrade from dell site, now when i start the computer it beeps and nothing happens. I need solutions! Thanks, Pablo
How many beeps? Any pattern? (e.g., short, short, long, long, low, high) ?
Contact Dell, and purchase a replacement motherboard.
Sep 02, 2010 | Dell Precision Workstation 670 PC Desktop
DELL Precision Workstation 670 second processor not working
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
Dell 670 BIOS not installed
If you are installing a new hard drive, it is possible that you have not connected the cables correctly. Check if these are seated firmly in the corresponding pins.
Aug 31, 2008 | Dell Precision Workstation 670 PC Desktop
Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Jan 18, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 PC Desktop Logo
3,276 people viewed this question
Alun Cox
