Question about Britannia SI10T6L Dual Fuel (Electric and Gas) Kitchen Range
Model number SI 9TF GRA Britannia Range Cooker
The oven door closes but then drops open a couple of inches.
  • 1 more comment
  • Anonymous Nov 25, 2008
    Britannia says that the hinge springs lose their tension ... and the complete hinge assembly for a pair is about £60. Easy to replace yourself.
  • FixJas Dec 29, 2008
    Does anybody know how to change the roller guide assembly for a Britannia oven door? The hinge assembly is no problem.
  • Ian Trimmer Sep 12, 2012
    Has anybody any idea how to change the rear circular element in the large oven on a 9TF EG Britannia Cooker? Ian
My larger oven on my britannia range has stopped working would it be the themostat and how much would this cost and can i fit it myself? the grill is working and so is the small oven can anyone help please. ben.
Posted on Aug 07, 2010
  • 3 Answers
Take the door off (easier said than done) then undo the screw below the static part of the hinge. It can then be dropped from behind.
Posted on Feb 16, 2009
I need some instructions how to change the lower oven element in my britannia SI-12T7 cooker. the element has screws that will not unscrew from inside the oven. any ideas?
straight forward to do. undo the screws to the back panel of the oven.
once remove down at the bottom of the oven you will see where the heater element comes through . there are to main feed wires that are pushed on and one earth wire. pulls these off as they are just push fit.
the element its self is a flat plate with 2 self tapper screws undo these and the element will then come out of the front of the oven. you have to lift it on a slight angle so the feet of the element will come through . hope this helps
Jun 16, 2014 | Britannia SI10T6L Dual Fuel (Electric and...
Britannia si-12t76x2
If your oven has no heat you'll need a new oven element, if your oven is cooking food too quickly/burning at the back then you'll need a new fan, if the oven is burning everything you'll need a new thermostat, if the oven isn't working at all check that the clock/timer hasn't been set for auto ie make sure it is on 'manual cooking'
Jun 16, 2012 | Britannia SI10T6L Dual Fuel (Electric and...
Need replacement glass grill door-outer for my Parkinson Cowan Cooker No. OVA60TCGRN
Looked on all available spare parts sites and found it on none of them.
I sooo wish I had not found time to take it apart to clean!
Jun 30, 2010 | Parkinson Cowan SG320 Gas Kitchen Range
Oven too hot - right thermostat needed
Try cleaning the thermocouple first. That is the long skinny looking bulb mounted inside your oven. It tells the thermostat what to do and should be cleaned every six months. You can do it inside the oven. If that doesn't help, please contact your service center. Here is the owners manual.
Nov 05, 2017 | Britannia SI10T6L Dual Fuel (Electric and...
Where can I obtain a user manual for Britannia model number SI-9TF-GRA
Jun 10, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Need manual for Britannia ilve range cooker
You may have the cooker oven set to automatic. Phone their Service Team on 01253471111 option 3. They will help you fault find. The ID strip with all the cooker information is inside the right hand oven on th right hand side.
Jun 08, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Brittania SI/9TB/SS fan in main ove glows red hot
There is a fault on you oven please ring Britannia for a service call on 01253471111 option 3. They can also supply a new oven seal
May 07, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Id number for range
The id number is in the right hand oven on the right. It sounds ans though the cooker is a 90 or 100 wide with chef top or fish burner. An instruction bookcan be sent in pdf format by contacting
Dec 21, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Selector knob not working
I think you will need and engineer to fix this. Call Britannia on 01253471111. They also have different ervice plans to cover your cooker regardless of its age
Jun 22, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Britannia SI10T6L Dual Fuel (Electric and Gas) Kitchen Range Logo
2,760 people viewed this question
Top Britannia Kitchen Ranges Experts
James Gettemy
Level 1 Expert
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
