My computer keeps rebooting ,so I bought a new hard drive and made original drive the slave, it still kept the problem, then I bought a new power supply, still no change, then I bought more ram and it is still rebooting any where from 10 minutes to 2 hours, this is becoming very frustrating for me . My husband is dying and I am paying doctor bills and don't have any more extra money to put into this computer.. Can you help me? Donna Dalton
  • doloda Sep 01, 2008
    I will have to wait on my son to come from his town (80) miles from here to check it out, but he also said it was probably the motherboard. I don't know when he will come
    I will get in touch when I see him
    Thank you Donna
    Genius:
  • 1,847 Answers
The issue is with the motherboard that is the green board inside the computer.
Posted on Sep 01, 2008
  • Legin Varghese
    Legin Varghese Sep 01, 2008
    do the following things before replacing the motherboard..
    Take all the Card off the motherboard if any (video /Sound/lan)
    now try working on the pc.
    if you have two memory cards take one out and try rebooting
    try the same with all the memory slots.
    Master:
  • 763 Answers
If you dont mind try to format it and i hope it should solve the problem. if you have a partition then transfer the important files to another partition and format the remaining partition.
cheers
CHARCOIS
  • 1,879 Answers
You already replaced major parts that causes reboots & the only thing left is the motherboard.
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
Hi I want change the hard drive on my desktop from 40 gigabytes to another one of 160 gigabytes or more. How can I save and keep all of my information and programs from my original hard drive to my new...
These computers will accept a second hard drive, (Master = C Drive & Slave = D Drive)
The easiest solution is just to install another hard drive which will then become the slave drive.
You can then transfer all your personal information onto this drive using windows explorer while leaving the bootup, operating system and any exisitng software on the exisitng drive. Any new software can then also be installed on the new slave drive.
All cables (IDE & Power) will already be within the computer but you may need to enter the BIOS at startup and select Auto Detect for the slave drive. You must also ensure that the new drive you install has the correct jumper setting i.e. Cable Select.
Jul 23, 2011 | Dell Dimension 3000 PC Desktop
I'm having trouble adding a secondary older hard drive in my ET1831-07. Do I make it slave and do I use the power plug labled "PC"?
if it is on the same cable as the original hard drive, you must ensure that the original drive is jumper set to master, not single, and the new drive is set to slave. if the connector is a 4 pin molex cable, and it will fit easily in the power connector, it will power your hard drive.
Jan 20, 2010 | E-Machines Computers & Internet
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
I was installing a dvd drive, unhooked main power supply in computer, now when I turn on computer it says it needs a systems reboot disc can you help
The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
Oct 04, 2009 | Computers & Internet
Computer keeps re-booting while installing any operating system
Were the two power supplies you tried inclusive of the original failed drive or not. In other words did you try a total a 3 power supplies including the one that failed?
If not, please do so. That is, immediately analyze the original known part failure, the power supply or its connection to the board(s) you have tried.
Congratulations for such an exhaustive process of elimination.
Apr 21, 2009 | Tyan Trinity S2090 Motherboard
Problems with my hard drive
You should be able to slave the old harddrive to the new one regardless of manufacturer. In the event that the drive is not "browseable" via Windows explorer, you should still be able to use DOS commands to copy the data files from the old harddrive to the new one.
Mar 27, 2009 | Computers & Internet
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Robert
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
Windows won't start
Try your jumper settings on the new drive. Should be set to "slave".
Also your bios settings, make sure your booting the right drive first..
Hope this helps.
http://datasip.net
mimi...
Jan 15, 2008 | ASUS A8N32-SLI Deluxe Motherboard
La Cie porsche drive not showing up on my computer
is the drive set on slave or master or cable select if this is the case then chane jumper setting toi master if booting with it on secondary ide but if on first ide then slave and if you have got files on these drives move them off then goto disk manager and delet partition then create new partion and sormat drive then set active in manager properties now reboot machine then open my computer to find the new drive hey presto working hdd
Mar 08, 2007 | LaCie (300803) 60 GB Hard Drive
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
