Question about Samsung HLP4663W 46" Rear Projection HDTV
Blinking lights I have the samsung dlp hlp4663wx/xaa..... The tv wont get a picture...It comes on, hear the sound....It did this a while ago, but it corrected itself....Now it will not come on at all, and to add to the problem it is makeibg a loud vibrating noise when it is on.....I have no idea what is wrong with it....
Sounds like the color wheel. Check for a replacement. Check the video on youtube of a guy fixing his color wheel to see if its something you want to tackle. I changed mine... a drag, but not too awful. Ran about $100.
Posted on Sep 06, 2008
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
Jun 11, 2012 - Uploaded by
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I have a Samsung DLP model HLP4663wx/xaa and the video keeps cutting out
and any sort of fan like or high pitched sound coming from the set?
Jun 07, 2012 | Samsung Televison & Video
Hello I have a dlp samsung hlp4663wx/xaa. Last week the picture went black the sound is good . I replaced the lamp and the problem continues . I also replace the color wheel a year ago. know everything is...
It is the DMD board especially if the lamp stays lit. If the lamp is not lit... Be sure you have the lamp in properly...that is plugged in good and the door has the door switch engaged. Be sure door switch is still good and did not get damaged when replacing the lamp. DMD board can be found at encompassparts 1-800-638-3328 for 318.51 plus 150.00 for the core but right now is on FACTORY BACKORDER Part number
BP96-00678DCurrently on Ebay for 179.00 plus 15.00 shipping. Enter part number in search
Oct 24, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663WX/XAA picture went out, started making strange noise, all lights on power button came on.
Sounds likea bad color wheel to me, or possibly a lamp has blown. If the noise is a humming sound--it is the CW--if you hear a "sound like a sizzle, for a few seconds and then normal, and this repeats a few times--the lamp has blown.
Oct 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I hear sound but no picture!!!!!!
If your using dubbing wires to connect to tv then check or replace the video input wire
Aug 28, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp mod# hlp4663wx/xaa 2004, When power is turned on the indicator lights for "lamp" and "timer" come on but, no picture? Then the tv will power off, then on and repeat the...
I don't have the manual handy at the moment. but if you look in the owner's manual you should see that this is the code for either a lamp or fan problem. I will look it up myself later, but check the manual. This could be as simple as replacing the lamp.
Sep 23, 2008 | Televison & Video
56" samsung dlp hlp5663wx/xaa
sorry Im so late. do not replace bulbs if u just had a nice clear bright picture!!!! stress this!!
indicator lights blinking "scream help I am shut down" normally due due to a short...and worse possible is the high voltage went bad, 2nd the power supply itself drooped a voltage or shorted.
good luck ..... I wish I was there to check it out with just an ohm meter.
Jun 16, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
230 people viewed this question
Jerry Greenberg
Jerry Greenberg
