Question about Dell Inspiron B120 Notebook
Stop: c0000135 {Unable to Locate Component}
Thats the note that would come out on the screen, every time I reboot..
IT all started when I interupted , "System Restore" .. it take so long that i shut off the power..
pls help.
  • semron08 Sep 12, 2008
    unable to connect to the internet
  • Anonymous Apr 21, 2009
    I have the same problem but its for my Inspiron 6400 laptop. It also says that it can't find KERNEL32.dll.
    Will using a boot disk solve this problem as well?
    Genius:
  • 2,028 Answers
Interrupting a restore is bad, very bad, but I guess you figured that out. At this point, you're going to need to start by doing a bios flash. Use another machine to download the system bios from Dell's support site and create a bootable disc. There should be a section for creating a bootable disc in the downloads. Run the disc in your machine, then do a system repair with your recovery or operating system disc. This will cure the glitch that was created during the restore interruption.
Posted on Sep 01, 2008
I am getting stop: c0000135 unable to locate component, this application has failed to start because MSVCR80.dll was not found.. how do I fix when i cant get past the blue screen?
Not sure what os you're running, and assuming it's xp, but see helpful links below.
To get past the blue screen, you need to press f8 during boot up, try using last known good configuration to start windows. Otherwise, try booting into safe mode. See the Reboot instead of shutdown section in this article. to disable the restart on system failure. Also helpful may be this link or this link or this link. Here's one more I saved. Unfortunately, many of the MS links are no longer valid, now that support for xp is dropped.
If you can run chkdsk on the system, you might be able to recover corrupted or bad sectors that caused the dll to be lost. For a list of device error codes, see here.
Also consider the possibility that malware is responsible. In that case, use MBAM to scan the system.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 21, 2010 | Computers & Internet
When starting the computer, after the Windows XP logo screen, I get a black screen that reads "Analog input cannot display this video mode." When I clear that screen, I get a blue screen with the following...
Boot your computer2_bing.gif to safe mode and change the display settings to either 800x600 then save and reboot2_bing.gif once it comes back up you can change the display setting to what you prefer.
To get into safe mode press F8 on you keyboard2_bing.gif every second while it is first booting up.
Mar 09, 2010 | Microsoft Windows XP Home Edition
Stop: C0000135 {unable to locate component}
ok if is win xp just run the xp cd and choose repair that should solve it
Aug 31, 2009 | Dell Dimension 2400 PC Desktop
ArcSoft Connect Notifier has stopped working
ArcSoft Connect Notifier has stopped... Solve Every time I switch on my lap-top,I get the same msg, "ArcCon.ac - Unable To Locate... (More) Every time I switch on my lap-top,I get the same msg, "ArcCon.ac - Unable To Locate Component" in the title bar with "This application has failed to start because ArcCon.dll was not found. Re-installing the application may fix this problem." Can any1 help?
Aug 08, 2009 | Arcsoft Print Creations - Cards &...
Stop: c0000135 {Unable To Locate Component}
Please follow these instructions to correct this error. I recommend you begin by scanning your system for malware by following these malware removal protocols. After scanning for malware, if you continue to experience this error, scan your hard drive for errors by running chkdsk. (link here.)
If you can no longer start your system because of the registry corruption, please see this article and the links within it...click here.
Jun 05, 2009 | Dell Latitude C600 Notebook
Dell Vostro will not boot up
During startup, just before the Windows splash screen appears, you should be able to hit the F8 key for a list of startup options. It looks from your post as if you know how to do this.
One of those choices should be to disable automatic restart on system failure. (or words very similar to that.) Use this choice to get into safe mode if you can, or into regualar windows.
Once there, go to the system restore feature and restore to a date when everything worked.
This error message is a message pointing to a piece of software (as opposed to hardware, as so many of these messages are).
The next best fix is to reinstall the OS from the ground up. this may be a major hassle, depending on the data you have on that hard drive.
Good luck
tony
May 18, 2009 | Dell Vostro 1700 Notebook
When starting up Windows XP - the process stops and I get the message C0000135 application failed because user32.dll wasnot found. I have tried to start in safe mode but the same problem re-appears. ie:...
I've just seen this on another users pc, here is how i solved it:
Start from your xp disk (recovery disk that you got with your machine or retail copy of xp), when prompted go into recovery mode (press r at the menu)
when in the recovery mode go to c:\windows\$NtServicePackUninstall$ and type
copy user32.dll c:\windows\system32\
then type 'exit' without quotes to reboot
your system will now boot up fine
(note there may be a copy of the user32.dll file in c:\windows\system32\dllcache\ as well)
Dec 10, 2008 | Computers & Internet
Laptop worked fine the other night went to shut it down and it then said that an update was needed before it turned off so it done that and then turned itself off.went to turn it back on the next morning...
boot up computer and as screen starts up keep tapping F8 to go into safe mode and then go to system restore and restore to a date before the update and it should work for you ..... it may have not been a real update or it just didnt load right / larryyb
Nov 28, 2008 | Acer Computers & Internet
Stop: C0000135{unable to locate component}
I believe that definitely your hard drive is bad and needs to be replaced. Also going by what you are saying here, your cd rom could be bad. If it is still working though, then most likely the reason that your computer isn't finding it or cannot boot from it, is because, due to your hard drive being bad, your computer cannot access the drivers to your cd, thus making it undetectable. Thanks
Sep 01, 2008 | Computers & Internet
User32.dll error message
I suggest you go do a google search and look for spybot, it has a registry FIX and scanner built in that will successfully immunize your system from hijacking website cookies and trojans, and bring your system to as close as functional as possible, then go to download.com and grab AVG anti-virus, do a complete scan, delete everything that shows, or quarantine after a successfull complete system scan. Be sure to reboot after EACH successfull AVG scan, as the program cannot delete high memory cookies or hijackers, and can only do at a system start up, before these programs go into high memory(RAM bits and bytes that users cant touch when a system is operational and fully booted up).
I hope this helps you a bunch, I have had the same DLL problems with my father's PC being hijacked from REGISTRY EDITOR cookies and trojans, mostly harmless key coder programs to watch your surfing.
If this does not help, then you are past repair on my levels and require a reinstall of the operation system and clean format of your drive. Attempt to backup all your important files to a DVD or TWO so that you can recover.
LAST RESORT is to partition the drive that you are using, and set up a system restore for your windows on this partition, if you EVER get this type of error again, if its not a corrupted video card or system driver, you can restore your PC on a clean backed up system, and retain all of your files and documents.
Just a suggestion, most will find this usefull..
ManOWar
Aug 09, 2008 | Dell Dimension 2400 PC Desktop
Dell Inspiron B120 Notebook Logo
607 people viewed this question
Alun Cox
