Question about Refrigerators
Both fridge and freezer to warm - Refrigerators
BOTH FRDIDGE AND FREEZER IS WARM, WHAT CAN BE THE PROBLEM?
Posted on Feb 11, 2009
  • AOChief Feb 11, 2009
    Both Fridge & Freezer is warm
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Freezer is too cold (-14 degrees) and fridge is too warm (51 degrees). The freezer keeps gettting colder but the fridge part keeps getting warmer.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The temp sensor for the freezer may be reading the warm air in the fridge so is not cutting the compressor off.
Sep 25, 2009 | GE Profile PDS20MFS Bottom Freezer...
Jenn-air JCD2289ATW Freezer perfect but refrigerator is warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Jenn-Air JSD2789GES Side by Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
Fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Jan 12, 2009 | Fisher and Paykel Active SmartĀ® E522BR...
What do you about the Fridge Freezer getting warm?
I HAVE HAD THIS PROBLEM ALSO,THE FRIDGE PIPEWORK HAS A GAS LEAK.
Dec 03, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
