Question about Nikon D200 Digital Camera with 18-200mm Lens
Blank LCD screen
Suddenly stopped showing shot being taken, but plays it back after taking: have I turned it off in error, or is there a problem??
  • 3 Answers
Check your manual, page 141: Image Review. Should be set to ON (default is OFF).
Posted on Sep 11, 2008
SONY DSC T33 SCREEN STOPPING SHOWING. CLICK SONY DSC T33 SCREEN STOPPING SHOWING. CLICK BUTTON,FLASH WORKS AND IT APPEARS TO TAKE A PHOTO BUT NOTHING SHOWS. ALL ISONY DSC T33 SCREEN STOPPING SHOWING. CLICK...
This is due to failure of ccd imager chip in your camera, replace ccd imager chip to get live view in lcd to take fresh pictures.
Let me know if you need ccd imager chip part number.
Sep 28, 2010 | Sony Cyber-Shot DSC-T33 Digital Camera
Why is canonS3IS screen blank
Please clarify your problem so someone can help you.
1. Does the camera power up? It has good batteries and the Status Indicator LED lights up showing that the camera has adequate battery power?
2. Is the screen blank when playing back previously taken photos also, just during recording, or all the time?
3. Can you see the camera menu's ok but not the live view of the subject.. or is everything blank?
4. Are you quite familiar with the menu's and most aspects of this camera model and you're sure all the settings are correct?
Please provide more detail.
In the meantime check the basics such as:
1. Press the display button on the back while the camera is on. This toggles the display setting between various settings such as Off/ On / Info. The screen may be switched off.
2, Check that the monitor brightness setting is set to medium at least in the menu's.
3. If the problem is only affecting recording then check that the main record settings are correct for the type of scene. For example don't use Beach, Snow, Candle or manual with a super high shutter speed while taking regular daylight shots.
2nd example .....If you set the shutter speed really high such as 1/1000 second while using indoor lighting the shots will be very dark.
4. If the LCD display has a hardware issue you could connect the camera to a TV using the video output jack and look at it that way. Then you'll know if the built-in LCD is ok or not.
5. Having a damaged or stuck video output jack WOULD cause this problem also,, since that circuitry is designed to automatically shut off the built-in LCD display when you connect a video cord to it. So leaving a cord plugged in to the video jack would shut off the display.
Jun 29, 2010 | Canon PowerShot S3 IS Digital Camera
Lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Dec 23, 2009 | Canon PowerShot A85 Digital Camera
I have no LCD screen when my E300 is turned on, it stays blank until I take a shot, the LCD screen shows this shot for a couple of seconds and then blanks again.I can't seem to find the problem in the...
Have you tried pressing the 'INFO' button? This little button will toggle between camera info on display/no info on display (when the display isn't in use to display pictures).
Oct 19, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
No picture display when taking shot. Blank pictures produced when shot taken.
Solution:
Ebay has used cameras (DX4530) for about $75.00 with shipping. Kodak's repair service for these cameras is done by mailing in the camera -- and the baseline starting price is about $140.
I'm planning to go to Ebay and buying from a seller with a good track record and reputation.
Mar 27, 2008 | Cameras
Blank LCD screen on shooting mode, but does show settings. Will not take pictures. Replaying mode works, shows pictures taken before screen went blank. New batteries. What is going on??? Is it...
The Display button manually turns the LCD display on or off to save batteries. If you accidentally had turned the LCD off, It should only take one press of the button to turn it back on and leave it that way. As such, it's not you but the camera. The A570 IS is relatively new. Your camera is likely still under warranty. If so, contact Canon for warranty repair (see the following link):
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2113&fcategoryid=221&modelid=14905
Mar 15, 2008 | Canon PowerShot A570 IS Digital Camera
File Error
i have the same problem too! ughh it so annyoing.
Feb 27, 2008 | Sony DSC-T70 Digital Camera
File Error
I also have the same problem
Dec 17, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Nikon D200 Digital Camera with 18-200mm Lens Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
