Question about Canon PIXMA iP1600 Printer
Waste ink basket full Canon iP1000
Greetings:
How do I empty or clean the waste basket? Where is it located? I could not find my product /- Canon iP1000.
  • 1 more comment
  • emiliabergin Oct 06, 2008
    i have the same problem
  • Anonymous Oct 09, 2008
    yo tengo el mismo problema
  • operation93 Oct 16, 2008
    same problem waste ink basket full canon ip1000
  • 4,041 Answers
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
  1. Turn off the printer
  2. And unplug the printer power cable
  3. Press and Hold the POWER button
  4. Plug the power cable again
  5. The indicator (LED) should be green
  6. Press and Release the RESUME button, the indicator (L.E.D.) should be orange
  7. Press and Release the RESUME button again, the indicator (L.E.D.) should be green
  8. Release POWER button
  9. Windows will detect new printer and you just have to install it again.
  10. It will create a copy of Canon i320 printer. Just delete the old one and rename the copy.
  11. You are done.
Posted on Feb 13, 2010
Pixma 150 waste
hi
you need to buy the waste toner container (its inexpnsive, plastci container that holds waste toner
go to this site first and follow instructions on HOW TO CLEAN THE INK ABSORBER
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Feb 04, 2012 | Canon PIXMA iP1000
Wast ink absurber full..error27
Hi
The wast ink absorber full, if you want to clean the ink absorber at home without wast money, i will provide you the example in Canon printer,how clean you ink absorber follow the mention below instruction and remove the error of ink absorber.
God Luck
Sep 05, 2011 | Canon PIXMA iP1000
Message about ink asorber full keeps appearing
When the printer is not being used, the print-heads slide to their "resting" position,
in order to keep the ink-jets moist, i.e., to NOT dry-out.
Some ink is absorbed into that INK-ABSORBER.
Now, after a few years of usage, that ink-absorber is "full".
Like taking-out the garbage from your kitchen waste-basket when it gets full, and replacing the full waste-basket with an empty waste-basket, it's time to get your printer serviced -- replace the "full" ink-absorber with an "empty" ink-absorber.
Note that CANON printers do not actually "measure" the fullness -- they electronically estimate the fullness, given information about how much you print, and how often you print, and the "density" of the pages that you do print (text is much less dense than colour-photos).
Mar 09, 2011 | Canon PIXMA iP1600 Printer
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
What does Waste Ink nearly full mean? Canon MP370
If you peel enough apples, and throw the "waste" apple-peel into the basket, eventually the basket gets nearly full, and must be emptied.
Similarly, if you print enough pages, some of the ink becomes "waste",
and that "waste-ink" goes into a small sponge-and-bucket apparatus.
So, take the printer to a qualified technician, and get the printer serviced.
Nov 23, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Waste ink tank full
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
I tell you what. Before you decide to reseting the waste ink counter, you should really clean up the ink absorber, or else you will find the ink watse absorber overflow...
Aug 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
My printer canon pixma ip2000 wont print there is a message on the monitor saying that my ink waste absorber is full
follow the link
Jul 27, 2009 | Canon Office Equipment & Supplies
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
This is a Canon PIXMA MP 780!!! Waste Ink Full Problem
You can try to read these articles on how to reset the waste ink full error on canon printer. http://www.fastrepairguide.com/waste-ink-full-error/how-to-repair-canon-ip1000-waste-ink-full.html http://www.fastrepairguide.com/waste-ink-full-error/canon-waste-ink-full-error.html They even provide the service tool program for reset the printer eeprom data(set as factory default).
Sep 10, 2007 | Canon I990 InkJet Photo Printer
Canon PIXMA iP1600 Printer Logo
303 people viewed this question
old marine
old marine
