Question about HP Jornada 548 Pocket PC
AC Adapter Buzz Noise
Hi, I have Jornada 548. The AC Adapter/Charger makes a buzzing noise when it is connected to the power, and the noise gets louder when Jornada is connected to it for charging. I'm thinking it's the transformer inside the adapter making the noise. Can someone tell me if this will cause any harm to my Jornada?
    Master:
  • 450 Answers
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Posted on Sep 12, 2005
SOURCE:
Buzzing noise
It could be feedback from your speakers... Make sure your power cord is grounded and if you have a sub or surround sound don't set the ac power adapter near them.
Mar 15, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
My Power Adapter on My Goodmans LD1925W semms to be getting really hot and since this my TV has picked up a buzzing noise and horizontal line runing from bottom to top like it's wanding from the signal but...
The power supply may fail as the capacitor that smoothes the rectified AC current is not working correctly and causing horizontal moving lines and the buzz.
If you can repair it by replacing the capacitors, all to the good but a switch mode type unit will possibly be available from an electronics shop.
Oct 31, 2010 | Televison & Video
My powered mixer Behringer is buzzing
Make sure the buzz doesn't happen because of feedback of speakers into mics. When feedback is processed it often goes to a buzz instead of the usual howl.
Also check that you are running adequate inout into the effect since a very low inout will incur digitizing noise and loss of signal=to-noise ratio.
Jun 02, 2010 | Behringer POWERED MIXER, 20 CH, 400 WTS...
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
Humming sound coming from the small speaker over my head ?
That "speaker looking thing" above the drivers head on the headliner is a part of the climate control system.
Here is the GM bulletin regarding it if you are running in to these issue:
Document ID# 1639237
Subject: Buzz Noise From Headliner Above Driver - keywords ac air aspirator cover fan grille HVAC interior microphone sensor speaker temperature vent vibration #PIT3511 - (03/29/2005)
Models: 2000-05 Cadillac Escalade
2002-05 Chevrolet Avalanche
2000-05 Chevrolet Silverado, Suburban, Tahoe
2000-05 GMC Sierra, Yukon, Yukon XL, Yukon Denali
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in the PI.
Condition/Concern:
Dealer or customer may comment that they have a buzz or vibration noise emanating from the headliner in an area that looks like microphone or a speaker.
Recommendation/Instructions:
The plastic escutcheon grill, which is round and about the size of a half dollar and located just above the driver to the left, is the interior ambient temperature sensor. The sensor is used in conjunction with the automatic HVAC (C68). On occasions, this sensor has been known to make a buzz or rattle sound. The sensor uses a small fan to pull air over the sensor. This buzz noise may be intermittent.
Although it may not be possible to alleviate all of the buzz or noise from this sensor, Engineering has found that if the sensor is installed incorrectly that it may bind and cause the fan to make a buzz noise. Remove the sensor and while doing so check for any binding. Reinstall the sensor and re-test. If the noise is still present, the sensor itself may be noisy and require replacement.
Mar 31, 2010 | 2004 Chevrolet Silverado 2500HD
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
I'm trying to use an FM transmitter to send radio programs from my laptop to digital radios in my home. Currently the system produces a loud Buzz along with the broadcast. The only way to eliminate the...
if you power cord is only two prongs and not three that is your problem. there is no ground. if there is three then you might hav to plug it directly in the wall outlet. then if it still does it try a surge protector.
Jul 02, 2017 | Dell HQRP Replacement Laptop AC Adapter /...
Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Jan 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
HP Jornada 548 Pocket PC Logo
348 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
