HI, I have an epson stylus color 740. It has begun printing black ink marks along the left edge of the paper, top to bottom in a regular pattern. I changed the ink cartridge and it still does the same thing. Any Ideas what could be wrong?? Thanks Robert
-   short black lines, mostly on the left.
Sometimes off the print area when I'm lucky
-   Guest
Oct 11, 2008
-   Same exact issue
-   Guest
Oct 09, 2008
-   I also have the same problem it looks like its returning after the last line of ink on the proof and leaving half of a zero in black at the end
-   Guest
Popular Solutions for Epson Stylus Color 740 InkJet
print head out of sync and making a screeching noise and the head appears to bang on the end of...
(More)
print head out of sync and making a screeching noise and the head appears to bang on the end of travel . The belt appears to be ok.
what should be the power supply if it happens that the fuse is ok?cause the power supply i'm using...
(More)
what should be the power supply if it happens that the fuse is ok?cause the power supply i'm using is still working properly. it has a 110 input v.
