Question about Camping, Backpacking & Hiking
Maglite LED. Light switch is intermittent. Have had the same issue with my 8 month old 2AA LED Maglite, don't have receipt and have tried finding a solution to get it fixed again. Lost my temper with it on a job on Friday night and smacked it into a flight case several times (was doing some urgent troubleshooting midway through the show) which seemed to fix it temporarily, however started playing up again Saturday night. The next solution was ebay and getting a new one, and this time I will be keeping the receipt and paperwork. I hope we have just been unlucky as there doesn't seem to be many people with the same issue.
  • Doc62 Jan 09, 2009
    Seems to be a common fault, I have 2 x AA mags and both of them are doing the same thing. Another temp fix is to use a pencil with an eraser on the top of it to clean the contact at the 'bulb' end of the battery compartment.
  • 121 Answers
Unfortunately not, I've seen more and more of these coming back to the shop here with faults. Mostly they seem to be connection problems like yours.
Pity, MAG are excellent and have really tarnished their reputation with this LED gimmick. A lot of the customers who return their LED's to us take a traditional MAG as a replacement..
Posted on Oct 09, 2009
    New Friend:
Take the battery cap off . Remove the spring and drop it on the batteries. Tighten the battery cap back on (this will require pliers ) . Forces contact inside and the light should come on .
Posted on Jun 09, 2015
Had the same frustrating problem, working in the dark and have the Maglite turn off with fresh batteries.  Would bang the flashlight and it would work for a few seconds and then turn itself off again.
Take at look at the two solutions at the link below.
1.  As mentioned in a previous post, is to clean the battery contact at the head of the Maglite..
2.  Push out the contact fingers in the tail cap of the Maglite.
After I applied both, my Maglite is switching on and off without a hitch.
http://www.maglite.com/pdf/CustServ/Mini%20Maglite%20LED%20FAQ5222007809312.pdf
Best of luck!
Posted on Dec 06, 2009
Is there a mini Maglite Led pro that takes 1 AA battery
Not that I know of- they are usually 2 AAs. The 1 AAA keychain model was terrible in that the "turn to on" function was intermittent so I could never trust it. Tried WD40, sanding the contacts, etc. This was the old halogen version.
Sep 03, 2015 | MagLite Mini Pro LED Flashlight with...
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
Maglite 2aa back cap won't come off
SOUNDS LIKE IT IS CORRODED. PUT A FEW DROPS OF RAPID TAP TAPPING FLUID OR A FEW DROPS OF THIN MACHINE OIL AROUND THE CAP. LET IT SIT FOR A FEW DAYS AND TRY IT AGAIN.
Feb 03, 2012 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
What kinds of a flashlight the brightest?
Check out this WEB site for super bright LED flashlights.
http://www.nextag.com/super-bright-led-flashlight/stores-html
Nov 28, 2011 | Camping, Backpacking & Hiking
I just replaced the batteries in my 2 D LED maglite with duracell alkaline batteries and after about 5 minutes use seem to have blown the led. Torch is less than 1 year old and has had limited use. Looking...
The resistor needs to be disconnected at one end -- if the LED is removed this should have the same effect as disconnecting one end of the resistor.
Put the probes of an ohmeter on each end of the resistor -- if it reads 0 ohms (or near zero), it is shorted.
Charlie
Mar 26, 2011 | MagLite Mag-Lite& Flashlight
MY maglite 2AA starts blinking
Unscrew the top head of the flashlight and check the contact points next to the bulb. if all else fails buy another one and take that one back and tell them it's defective.
May 10, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
2AA LED Maglite not working
The Led are most likely not burned out they last 10,000 hours or more. Sounds more like defect.
Sep 23, 2009 | MagLite Camping, Backpacking & Hiking
I have replaced batteries and bulb in maglite flashlight. Problem is still the same. The light comes on but immediately dims to very poor light. Can't get at switch ---it's a maglite.
Sounds like a bad switch, but if you live in the US, you have a limited lifetime warranty on your light.
Contact Maglite at: http://www.maglite.com/feedback.asp
You should also consider installing a LED bulb in your light. If you use it much at all, it will quickly pay for itself in battery life and the light is a lot whiter.
May 13, 2009 | MagLite Mag-Lite& Flashlight
Camping, Backpacking & Hiking Logo
1,952 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
