My big screen tv
When i press the power button on my tv it wont turn on but it makes a clicking sound then stops No power up! When power button is pushed the LED lights for approximately two seconds, I hear a click and the power light goes out! The self diagnostics shows three flashes on initial plug-in & code twelve when menu & input are pushed.
I've checked the input power-it is O.K. I've located two bad fuses, F9A04 open &F9A05 resistance value of 1.448 Mega ohms. All other fuses check good.
  • 8,617 Answers
Those are the two 5amp pico fuses that go out when the convergenec Ics go out on a mitsubishi. You can get the ICs and pico fuses at the following link. If youre not sure which ICs you need leave them a email with your model nuber.Heres the link
http://servicemanuals.vstore.ca/
Posted on Sep 01, 2008
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
My tv is an old rca tv, i have a dish network remote, one of the kids locked out the tv and i dont know how to get it back on, it wont tell me a anything all i can do is change the tv with the remote,...
If I read your post correctly it sounds like, the remote no longer works the volume or power for the TV set. If this is correct follow the steps below for a Power Scan. If this is not the issue or the steps don't work feel free to contact me and we will sort this out!
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Try several functions Mute Volume and Power to make sure the remote works properly then press "SAT".
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | RCA 32F531T 32" TV
The TV will not turn on.
I have the same problem, push button to turn on tv but it only does a click like it is going to turn on and then another click bit it wont turn on. Finally a red light is just blinking.
Any suggestions, is there a freeze button or code that I need to push.
Jul 03, 2009 | RCA HD52W140 52" Rear Projection...
Tv stays on after hitting the power button and remote stops working
it prolly is turned off but the image is burned into the screen
May 25, 2009 | Panasonic PV-C2020 20 in. Combo
Programming my remote to control the sound on my TV
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Jul 24, 2008 | DISH Network IR Remote Control
My big screen tv
this is usually a problem with one of the voltage regulators, or the horizontal output transistors.
Apr 23, 2008 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
