Question about Camping, Backpacking & Hiking
Coleman wide beam flashlight
How do you get inside to change the batteries?
4 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: How do you change the batteries on a Coleman
All The info I can find nothing tells us how to change the batteries. Is this a rechargable light, if so the batteries are not available for replacement. If not then the top has to screw off, or the bottom plate must screw off, there isn't any other way. What I have read is that these on this light are very hard to remove, at least that is what folks are complaining about. this light has also been discontinued and no longer availabe. if your afraid of breaking the light then I would contact Coleman for their advice since there seems to be none to be found on any bulletins they have put out.
Posted on Apr 28, 2011
I got it off. All you need is pliers. You take pliers and twist the bottom of torch with them. It'll come off in a minute or two, just keep twisting!
Posted on Feb 24, 2013
  • 5 Answers
SOURCE: How do you change battery in energizer flashlight?
no i need help closeing my microwave door
Posted on Jul 11, 2013
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
How to open Coleman battery lock flashlight
Sorry no idea with no picture . Coleman makes millions of lights . many unscrew either top bottom or both .
Oct 14, 2015 | Coleman Camping, Backpacking & Hiking
I have a coleman companion flashlight/lantern and need to disassemble it for battery replacement. i can`t fiqure out how.
Really? Put the flashlight down and slowly step away from it and if that doesn't work threaten it with a hammer?
Seriously did you read the package directions? The pointy end with the gray ring is the end most likely screws off to put the AA batteries in.
Jun 06, 2015 | Coleman Camping, Backpacking & Hiking
How do you open a Coleman flashlight
You need to specify the model of the flashlight. However, for most of them you simply unscrew the bulb head or the battery end cap, empty the old batteries and insert the new ones with the positive end of the batteries always pointing toward the bulb end and the negative end of the batteries toward the spring in the end cap.. Be sure to discard the batteries properly. Contact your local trash disposal company to determine where and how to dispose of them.
Jan 02, 2015 | Camping, Backpacking & Hiking
Corroded battery in high beam 1watt
battery sat inside to long or was overcharged... not worth saving
Dec 29, 2013 | Rayovac Highbeam Flashlight 1 Watt Luxeon...
5399 series cant unscrew anywhere to replace batteries very old metal version
I have the same flashlight. I had to use a vise grip and it took two of us but the bottom unscrews. Mine was due to corroded batteries inside.
Aug 06, 2011 | Coleman Graphite Flashlight
How do you change the batteries on a Coleman Graphite flashlight?
Apr 28, 2011 | Coleman Graphite Flashlight
How to turn on Model No. 3000001019 Coleman headlamp. I got the batteries in but it does not go on. How do I turn it on?
Make SURE you have the batteries in the right way. If you have a battery turned around it won't work, plus you will likely bend the spring inside and then be unable to get the battery in the right way.
Dec 25, 2010 | Coleman 3AAA LED Headlamp
I just bought the coleman Max mult-colored headlamp and i cant figure out how to put the three AAA batteries in
In the headstrap is a plastic 'key' that you use to remove the battery cover (opposite side of the headlamp from the switch). Once you remove the cover, you can shake the headlamp to let the battery cartridge slide out of the headlamp.
Pay close attention to which way the batteries go in--if you put a battery in the wrong way you can easily bend the springs inside!
Oct 26, 2010 | Coleman 3AAA LED Headlamp
Camping, Backpacking & Hiking Logo
103 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
