On 26 Aug 08 I downloaded a copy of Lotus Organizer 97 GS for Macintosh via Vnunet.
The programme was downloaded via my PC to a flashdrive which I subsequently loaded into my Mac Pro laptop which is running the latest Mac system X.
When I try to unzip the downloaded Lotus Organizer programme on the laptop I get the following message "unable to expand organizergs.hqx. Suffix archives not supported".
I would be grateful for any advice on how to get the programme running on my Mac.
As an aside, I run Lotus Organizer V5 on my PC, if/when I get the Mac version running will I be able to trnsfer the PC files to my Mac?
I've run Lotus Organizer for years on my PC (WIn98se) and recently migrated it to a MacBook, using a Parallels virtual machine running Windows XP. Works fine.
I was thinking of buying the Lotus Org for Mac to save booting my diary through the virtual machine (takes more time) but having 2nd thoughts if the software will not unload.
ChrisQiHmmm! Did you ever solve this?
ChrisQi
You can't post conmments that contain an email address.
I apologize for any confusion, but as of my knowledge cutoff in September 2021, Lotus Organizer is not available as freeware or for download as the latest version. Lotus Organizer is a personal information management software developed by IBM, and it is part of the Lotus SmartSuite package.
IBM has discontinued the development and support for Lotus Organizer, and the latest version available is Lotus Organizer 6.1, which was released in 2006. It is a commercial product that needs to be purchased from authorized software vendors or through second-hand sources.
If you are looking for a freeware alternative for personal information management, there are several options available, such as Microsoft Outlook, Google Calendar, and Thunderbird with the Lightning extension. These applications offer similar features for managing your calendar, tasks, and contacts.
Please note that the availability of software and its pricing can change over time, so it is recommended to check the official websites or reputable software sources for the most up-to-date information on the availability and pricing of personal information management software.
I would purchase this software which I use everyday and it will allow you to import your entire PC into a virtual image that you can run all the existing software and Vista just as you did before.
http://www.parallels.com/products/desktop/
Files with the suffix ".exe" are executable only under the Windows operating system. If you have an Intel iMac you can run Parallels software and actually install Windows side by side with the Mac OS and then be able to run ".exe" files in their native environment. Generally, downloadable program files for Macintosh have a ".dmg" suffix which is a disk image file which contains the actual program. After mounting the disk image on the desktop (by double-clicking) you can then copy the program file inside it directly to your hard drive via click&drag and then run it from the hard drive.
First download this software: Ultimate Unlocker v1.01 by Cruiser Team(search google its free!)
Follow the example given below:
Successfully unlock K660i (A2)
17:25:25 Ultimate Unlocker v1.01 by Cruiser Team
17:25:26 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
17:25:26 Initializing...
! 17:25:26 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:25:26 2. Choose the phone model
! 17:25:26 3. Select the desired options
! 17:25:26 4. Please connect the phone either via USB while holding 2-5…
! 17:25:26 - or via a serial cable and double-click on it in the device list
17:25:34 Connecting via Generic EMP USB Flash Device (USB1)…
17:25:34 Device driver version: 1.1.0.12
17:25:34 Device driver date: 9-25-2006
17:25:35 Connecting to the baseband CPU...
17:25:35 Entering baseband CPU service mode...
17:25:35 Detected chipset: DB3150
17:25:35 Boot mode: ROM
17:25:36 Sending loader...
17:25:37 IMEI: xxxxxxxxxxxxxxx 17:25:37 OTP CID: 52
17:25:37 Product type: Retail
17:25:37 Effective color: Red
17:25:39 Sending loader...
17:25:40 Communicating with server…
17:25:44 Remainig credit (supreme): 1.00
17:25:49 Remainig credit (supreme): 1.00
17:25:49 Converting phone to blue…
17:25:49 Please reconnect the phone (disconnect, connect while holding 2-5)
17:26:01 Sending loader...
17:26:02 IMEI: xxxxxxxxxxxxxxx
17:26:02 OTP CID: 52
17:26:02 Product type: Retail
17:26:02 Effective color: Blue
17:26:04 Sending loader...
17:26:08 Code NCK for relock: 9753585490502778
17:26:08 Code NSCK for relock: 3889412532359257
17:26:08 Code SPCK for relock: 3171907565654182
17:26:08 Code CCK for relock: 6478061648618760
17:26:08 Code PCK for relock: 3949070691496765
17:26:08 Code ESLCK for relock: 9101944641118096
17:26:08 Code NCK for unlock: 9012406338647640
17:26:08 Code NSCK for unlock: 2040670855123632
17:26:08 Code SPCK for unlock: 0923191541634191
17:26:08 Code CCK for unlock: 4556970785063717
17:26:08 Code PCK for unlock: 1754665636774190
17:26:08 Code ESLCK for unlock: 2257853277910517
17:26:08 To enter a code, type < * * < on the phone with SIM-card inserted
17:26:09 Turning off the phone...
17:26:11 Done.
! 17:26:11 Please disconnect battery and cable from the phone!
Alternatively you can do this:
hard reset *2767*3855# (this erases all ur data, you can preserve ur data by takin a backup.)
17:26:11 Done.
not farmilliar with this software but it uses a database dao object file try this method open my computer go to c: drive hit the search files button or ctrl+f and type in *.ORG this is theCalendar file (Lotus Organizer)
the *.org will search for the file till it is located then it's only a matter of opening the file and making backups of your calendar information try opening the file in lotus software. usually file open or import
Brandonp, I will suggest finding a copy of Microsoft Office (that's the only way I am sure of obtaining Outlook) as it contains Outlook. If you can use Outlook Express for your purpose? Then you can download that for free, but since Microsoft ** longer supports 98SE, I am **t sure you will be able to get it via Microsoft/Windows Update as XP and Vista users can. If Microsoft.com fails to let you download Outlook Express, let us k**w and I or one of the other Fixya Team members will provide a link for it's download. Keep us posted, and Good Luck.
You won't be able to do that. Lotus Organizer as well as Lotus Notes and OutHook are PIM some plus e-mail, just like Palm Desktop is a PIM. So you can have the Treo sync with Lotus Organizer AND have the Axim sync with it also it is because there are conduits buit for them. There is a middleware that allows both to talk to one. Now if you can find a piece of software out there that will sync a PocketPC with Palm Desktop, I'm sure a lot of Palm converts would love to know that.
ChrisQi
