Question about Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Problem
Motor appears to be burned out. Motor has 8 vdc across the red and black wires but still will not spin.
where can I buy a replacement? Motor is MMI-6T2RWK0
thank you
  • 515 Answers
If Sony does not have it available, you won't be able to find one. You can go generic, but you have to worry about size and fit.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
  • krakudden Jan 07, 2011
    The product number of the motor is: 176324711.
    You can order it from www.eet.se and other sites.
    The cost is about 75 dollars.
    Niklas
Sony turntable ps-lx250h won't stop turning it has to be unpluged. what do i do?
When the arm moves it contacts a switch which should start and stop the motor. Clearly this switch has broken and the contacts are now in the on position.
Jan 18, 2014 | Sony PS-LX250H Turntable
Sony ps-lx250H loud buzzing sound
That is where the problem is, get a long insulated wire, bare both ends and attach one end to the turntable and the ground screw of the amp, use one screw on the chassis on the turntable and bare the metal for good ground connection.
Jul 20, 2012 | Sony PS-LX250H Turntable
I received a SONY PS-LX250H turntable with the drive belt off. Where do I route the drive belt to get it back on?
The Operating and Install Guides are here...
http://www.retrevo.com/support/Sony-PS-LX250H-Turntables-manual/id/752ag608/t/2/
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C310321&fes=true&mdl=PSLX250H
Follow this procedure to install the belt on the turntable.
  1. Lift up on the dust cover [FIG. 1] and remove it from the turntable base [FIG. 1].
  2. Remove the rubber mat [FIG. 1] from the platter [FIG. 1].
  3. Lift the platter straight up off the spindle [FIG. 1].
  4. Slip the drive belt around the under side of the platter [FIG. 2]. IMPORTANT: Line up the ribbon that is attached to the belt with the square opening near the edge of the platter .
  5. Place the platter back on the spindle .
  6. Spin the platter so the square opening on the platter is over the motor pulley [FIG. 1].
  7. Stretch the drive belt [FIG. 3] over the motor pulley by pulling the attached ribbon [FIG. 3].
  8. Remove the ribbon from the drive belt .
  9. Reinstall the rubber mat and the dust cover .
Jan 29, 2011 | Sony PS-LX250H Turntable
My Sony PS-LX250H turntable will only spin at 45rpm. When i push the speed button for 33 it doesn't change. i also sometimes have to give the deck a little push to get it to spin.
I have the exact same problem for the same model. Only spins at 45 and I sometimes have to kick-start it. I tried de-activating the switch (so that it's not making a connection) and therefore in the 33 position but that does not help.
Dec 14, 2010 | Sony PS-LX250H Turntable
The turntable motor runs but the turntable doesn't spin i'm not sure if the belt is on incorrectly or what help please. Sony ps-lx250h turntable
most platters are secured with a c clip in the middle --gently prying it off should allow the platter to be removed--than a little dexterity is required to reattach the belt to the pulley and around the bottom of the platter--if the belt is broken or stretched you can pursue a replacement at mcm electronics .com
Sep 04, 2010 | Sony PS-LX250H Turntable
How do i replace belt on lx250h?
Not sure about yours, but some of these one lifts the rubber pad to get access to the belt through holes in the platter when you are re-installing to get the belt back on the hub it runs on. One usually has to lift the platter off to get the belt around the center hub and the motor pulley first..
You can probably find the belts online with a Google search.
Dec 10, 2009 | Sony PS-LX250H Turntable
Turntable ps-x55 / arm want move stay in lock mode
I have the exact same problem with my TT - a PS-X55. It appears that the motor has failed. Too bad, as I was told the replacement motor part is no longer stocked by Sony. For what it's worth - the part number is 154116500.
Let me know if you manage to find some who has the exact part stocked.
Jan 05, 2008 | Sony PS-LX250H Turntable
Sony PS-LX250H turntable won't turn
check the switch that make the lp running located it on the arm (arm uses to put it on the LP) check the motor Make sure no debris whatsoever that can disrupt the LP to turn
Aug 06, 2007 | Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Logo
1,139 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
