Question about Creda W100FW Front Load Washer
No spin goes thru cycle fine comes to spin and nothing jus makes clickin sound an no motor movement
  • Creda Master
  • 3,463 Answers
Probably needs new brushes in the motor
Posted on Dec 16, 2008
Whirlpool direct drive washer won't spin. It goes thru every cycle just fine but won't spin on any cycle. it is not the motor coupling
New washers have DC current motors now.. It is possible that the circuit board is gone out for it to go into spin mode..
Nov 06, 2016 | Whirlpool Washing Machines
I have a whirpool LSR7233DQO model top loader washing machine, a month ago it stopped agitating, now it will not spin at all on the spin cycle. It actually sounds like there is movement in the bade of the...
Sometimes the switch goes out (that little thing you held your finger on to keep it running). That's ~$20 to fix. If the washer runs, fills with water and won't spin once it reaches the spin cycle you probably need a new motor.
Feb 05, 2014 | Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Spin cycle not working
hi,
depending on the model, it may be that your plastic universal joint union has cracked and broken, they are replaceable. put the machine on its side and study the area in between the motor and the transmission. usually the motor has to come out and then the union is right there. dont forget to unplug it.
good luck
J
Jul 21, 2009 | Washing Machines
Fridgidaire front loader wont go thru spin cycle
This sounds like it is either part of the motor that is burnt out, or a fault on the control board that controls the fast spin speed.
The motors have a number of coils, so a fault with one will cause problems at just one speed.
The power transistors on the control board can also fail - leaving one speed dead, so either of these faults may be the reason yours is not working.
#1 - Check all motor coils
#2 - Check operation of output Power transistors.
Above tests should be performed by competent engineer only.
There is also another fault concerned with an unballanced load - If it spins a few times and bounces a lot, then it will abort the spin cycle. This is usually the fault of the dampers - which are a cheap replacement.
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Lsb6300pw whirlpool topload
does it wash have you tried on wash since youve had the spin promblem
Jan 13, 2008 | Whirlpool LSB6300PW Top Load Washer
Creda W100FW Front Load Washer Logo
76 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
