Question about Creda W100FW Front Load Washer
Crea w100fw makes clicking sound from knob on front cant hear motor moving ..any ideas
  • Creda Master
  • 3,463 Answers
New brushes needed in motor.
Posted on Dec 16, 2008
I have a 2000 jetta and when u turn the knob for roof to open u can hear the motor running but nothing happens any ideas
It sounds like the gear has stripped on the motor. I would take it apart and check the gear, and the rest of the moving parts inside for damage.
May 16, 2011 | Volkswagen Jetta Cars & Trucks
Hello, my washer will fill with water and I hear a relay click when I pull the knob (not just the knob clicking). I also hear a buzzing sound from the washer itself when I pull the knob out but it won't...
PRESS AND HOLD IN POWER BUTTON FOR 15 SECONDS SO THAT ANY INTERNAL ERROR CODES CLEAR THE SYSTEM. MAKE NOTE OF THE LIGHTS THAT FLASH. ATTEMPT TO USE THE SYSTEM NOW.
Jan 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Can hear water going in but carnt see any in machine and drum dosent move
Sounds like the motor or brushes try checking/ fitting new set.....
Jan 08, 2011 | Creda W100FW Front Load Washer
I am getting no sound on my eMachine T5048
Here is a link to the eMachine T5048 audio driver:
Click Here
Make sure that you also have the latest windows updates on your computer and that your volume is turned all the way up.
Nov 10, 2009 | E-Machines T5048 (7136) PC Desktop
I have a 2002 Mercury Sable 3.0. I noticed when
The clicking noise is the motor for the "blend door". The heater core and the air conditioning side share the same ducting. When you move the knob a small motor moves the door letting the respective hot or cool flow happen.
The heater core is probably blocked. The engineers at Ford have the coolant hoses bypassing the core with a WYE at the firewall. The coolant takes the path of least resistance and stops FLUSHING the heater core and it eventually clogs.
Oct 12, 2009 | 2001 Mercury Sable
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Wipers don't work
My 2005 Ford FreeStyle (AWD) Front wipers quit working...don't even hear a sound of the motor attempting to operate...wiper washer/sprayer operates fine. Rear wiper system operates.
What is wrong? Do I need replace the wiper motor? If so,how? Thanx
Jan 21, 2009 | 2005 Ford Freestyle
Frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Nov 02, 2008 | Frigidaire ATF6000ES Front Load Washer
No spin
Probably needs new brushes in the motor
Sep 01, 2008 | Creda W100FW Front Load Washer
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
44 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
