Question about RCA P52926 52" Rear Projection Television
RCA D52W19 screen flashing and won't turn on
Problem first started with the power button flashing 3 times and still not turning on. It woulnd take about 3 min., then 15min., then 1hr, then 3hrs, of pushing the power button to get the tv to turn on. We started not turning off the tv so we didn't have deal with the hassle. Then after a few weeks of this prossess if you were lucky enough to get the tv on in the middle of your show the screen would start flashing white with static. It started flashing about every 30 min or so and then moved to about every 5 min. I know someone who had a simular problem with a flat screen and said they fixed it by changeing out a lamp. I would like to know if anyone knows if this tv has a lamp that can be changed, where to get this lamp, and if they think it will work?
  • ang_pastor Nov 01, 2008
    I think I have the same problem. It was working fine, turned it off then after about 2 hours turned it on again, didn't turn on except the flashing light on the power button. What could be the cause?
  • 50 Answers
YOU DO NOT HAVE ANY LAMPS --BUT YOU DO HAVE 3 PICTURE TUBES...SORRY TO SAY BUT THIS IS THE WORST TV BUILT...LETS SEE IF WE CAN FIND A FIX...YOUR PROBLEM WILL PROBABLY NEED A SERVICE TECH BUT HERES SOME OF THE PROBLEMS THAT GO WITH YOUR SYMTOMS---WHEN THE SET TRIED TO COME ON WITH 3 FLASHING BLINKS,,IT'S GOING INTO SHUTDOWN...NOW...THE HV TRANSFORMER,,THE HV BLOCK AND SOME CASES ,,,ONE OF THE PICTURE TUBES LEAKING FLUID AND SHUT DOWN...CHECK UNDER THE TV FOR A FLUID LEAK-LOOKS LIKE ANTIFREEZE-THE WHITE STATIC THING SOUNDS LIKE HIGH VOLTAGE ARCHING...AFRAID YOU'LL NEED A CHECK OUT FROMM SERVICE TECH..TUNICA
Posted on Oct 30, 2008
D52w19 rca hdtv.will not tourn on. when u push the
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA D52W19 52" Rear Projection Television
RCA d52w19 green LED flashing and speaker int/ext switch problem
The most probable cause are the Three capacitors CP150, CP114 and CP120 all located on the deflection board.
Dec 13, 2009 | RCA D52W19 52" Rear Projection Television
TV will not power on. Button slowly flashes green several times
CP120, CP114 and CP150 need replacement. You can get replacements at the following link under the RCA parts catagory.
http://servicemanuals.vstore.ca/
Aug 22, 2009 | RCA D52W19 52" Rear Projection Television
My TV won't turn on.
If this is a RCA Picture Tube Rear Projection, the Deflection Board will cause this problem. I do not know though if it is available.
Jul 18, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 push power flashes 3 times and makes buzz each time
Check capacitors cp150,cp114,cp120 if any of the capacitors are puffed up on top replace all 3 of them 2200uf 16v and (2) 220uf 35v
Feb 14, 2009 | RCA D52W19 52" Rear Projection Television
52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Dec 09, 2008 | RCA D52W19 52" Rear Projection Television
Power button blinks 3 times
You need to replace the flyback, and that will fix your set. You can get a replacment flyback at the following link and they will provide free online instant messaging when you do the repair so they can take you through the replacement step by step. You need flyback number 259296 heres the link.
Aug 08, 2008 | RCA D52W19 52" Rear Projection Television
RCA TV D52W19
Describe noise.. Chirping 3 times? does the led on front flash
Mar 06, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 (52"HDTV)
The common culprit for this problem is a defective Focus/Screen control block. It is located behind a removable panel in the front under the speaker grill. It is a little black box mounted up along the top of the opening with two rows of three openings for adjustment of the Red, Green and Blue "focus" and "Screen" (brightness) settings. They often get contaminated with dust which is attracted by the high voltage flowing through this block. It is held on by a single screw and has 9 push on/off wires into the back of it. The replacement is fairly straightforeward, just keep track of which wires go where. Leave the set unplugged and powered down for a day or so and the voltages should all have bled away to ground by then.
Aug 01, 2007 | RCA D52W19 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
385 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
