You will need to reset the BIOS, and for that, open the case.
Reseting the BIOS is simple; open the case, find a small battery that looks like a watch battery, and take it out. Then hold the power button in for 30 seconds. Replace the battery, and the password should be gone.
There might also be a little switch or button labeled BIOS or Reset. You can use this to do the same thing.
Don't touch anything else while inside the case.
Hope that helps.
Just hit the set up key as your machine
boots up, usually, F2-F3 or F8.
Go to safe mode using the up-down arrows
and where it says set/change password, simply hit the enter button, enter a new
password in and close, using the save function.
You can now use that new password and are
now officially the administrator!
Or else, you need some Windows password reset program to help you do that job.
