Question about HP Jornada 567
Headphone output seems noisy
The headphone output seems noisy(a background noise is always present when the amplifier clicks on) and lacking bass. It really sounds thin and constricted. Is this typical?
0 characters
1 Points
User hears faint static while on a call. It's not load enough to make it hard to hear the caller, but a noticable crackling/static noise can be heard in the background. happens on every call.
Cell phones transmit the sound as digital data. The data when converted back to analog to listen too CAN have "digitizing noise" which will sound like static.
WORSENING the problem is if there is noise in the background of the person sending the voice and the worst possiblle is to have MUSIC in the background. These both drive the CODEC (the analog conversion system) crazy and will create what you describe. The CODEC is designed to transmit ONLY voice.
Oct 23, 2009 | Motorola Mobility Moto Q
No sound when I get a call or answer a call..? how can I fix this
if you had plugged in a headset or headphones to listen to music the phones a little slower and still thinks the headphones are in and if you take the battery out thats one of the things it saves so you still have the problem. For some people they can fix it by simply plugging the headset or headphones back in and taking them out slowly but for others this dosent always work, so what i found out you can do is stick a small pin in the headphone jack and wiggle it around untill you hear somthing ( have your pocket tunes turned on so you'll know when its working) then once you hear sound just quickley pull the pin out.
Hope this helps
Aug 15, 2009 | Sprint Centro Smartphone
How to route the sound of fm radio on LG ku990 to main speaker. Right now sound is available only for headphones.
to Activate the FM Radio through the handset speaker? Type 3845#*990# into your handset.
You’ll be presented with a menu called Test Mode
Use your camera wheel to select FM Radio Test
Use the Up/Down keys on screen
Press the C Key and then the Red Key to exit.
thanks to lg-phones.org for this :)
Apr 25, 2009 | LG KU990 Viewty
No sound
I had this problem as well. I would get sound from headphones but unplugging them I had no sound from the builtin speaker.
When you plug in your headphones it moves a thin piece of metal in the jack which interrupts a connection (this is a good thing) so it can know when to disable the internal speaker. When you unplug your headphones the piece of metal moves back and it enables the internal speaker again.
I was able to fix this by taking apart my x51v and bending the piece of metal a little while the headphones are plugged in so that it will contact better when the headphones are unplugged,
To take your axim apart there are 4 screws on the back underneath the rubber grips that you need to take out. Then you can just slide a finger nail up and down each side to remove the front and back of the casing. The back you will need to swing out from the bottom since it hooks over the headphone jack. I unplugged the small wire that connects the front half of the case to the guts using a tiny flat screwdriver.
Inside on the back, there is a black plastic plate that is held on by 4 more screws. Take that off.
Now you can see the headphone jack. I plugged in my headphones and used a small flat screwdriver to push against the headphone jack on the bottom piece of metal on the right side with the axim face down. You can observe the piece I mean by looking at the side of the headphone jack when you plug and unplug headphones. It moves perhaps 1/32 of an inch.
Your goal is to bend the piece of metal closer to where it is when no headphones are plugged in. The only way to bend it properly is to do it when the headphones are in.
Sorry if this isn't clear enough. I'm not sure if this is a permanent fix or not but it's worked for me.
Jan 04, 2009 | Dell Axim X51v Pocket PC
2 Sound problems with O2 Xda 2 Mini
Comment by noneedtoknow, posted on May 09, 2008WOOOHOOOOO, I FIXED THE PROBLEM!!!!
Basically what u gotta do is ...
when u shove the headphone into the port u msut pull it out real strong or really firmly so that it completely discharges from the o2. do it a few times and try out the sound, it should work
WOOOHOOOOOO I ROCK!!!!!!!!!!!!!!!!
THANKS IT WORKS
May 02, 2008 | O2 Xda II mini
Music on the Life Drive
I'm positive all LifeDrive users of Pocket Tunes experience the noise distortion between tracks. This appears to be a software issue more than anything, as TCPMP doesn't give you that "static wash" sound between MP3s that Pocket Tunes so nicely provides. So yeah, TCPMP gives a cleaner output. Haven't you noticed? The developer has worked to combat the LifeDrive's audio quirks. The most recent release also subdues similar distortion that would pop up during quiet moments of music, I've read. Honestly, I ditched Pocket Tunes the moment I noticed the crazy between-track stuff. I'm comfortable with TCPMP, and everything I've read on the TCPMP forums suggest the developer is currently working on ways to boost usability (i.e., playlists, what have you). You can add an extra layer of audio refinement to the mix, too, if so inclined; one that allows for entirely static-free music playback on the LifeDrive running TCPMP. Pick up a Radio Shack Volume Control Headphone Extension Cord 42-2559 (http://www.radioshack.com/product.a...duct_id=42-2559). This device acts as an attenuator. Output TCPMP at around 80% (give or take a little, especially when using the preamp) and control the volume entirely with the little "remote." It snaps securely into my LifeDrive headphone jack, adds no tangible weight to my chosen headphone cord, gives me out-of-pants-pocket volume control (great for when I'm walking or on the subway and don't want to flaunt my gear!), and only costs $6.59. Furthermore, TCPMP *does* support AAC. The devloper simply doesn't distribute a compiled binary of the plugin anymore. He used to, but got some heat for it, I guess. Don't ditch your current version of TCPMP, though. Browse the TCPMP forums for users that have created binaries of this plugin from source for people like you to download. I've read TCPMP can use plugins from previous versions, too, but you should find what you're looking for with a little browsing. Also, you can use JHymn on your desktop to "strip" the DRM off your iTunes Music Store AACs, for installation on the LifeDrive, etc. JHymn is a real solution for this kind of situation -- not a transcoder, for example. So, stick with TCPMP. It'll even play Divx movies very well with no further conversion. I just hope it will support background play, playlists and stop blinking my damned HD light at some point.
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Sep 15, 2005 | Palm LifeDrive Handheld
Record audio
Do I understand correct that you want to use the headphone jack for recording ? That´s impossible, The headphone jack in just for output signals. It´s not possible to use this one for recording sound.
Sep 11, 2005 | Toshiba e400 Pocket PC
HP Jornada 567 Logo
15 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
