Question about Quasar HQ2051TH Air Conditioner
Is there a fuse or reset?
My AC doesn't run at all. There is power at the outlet, but even the fan doesn't run. I can hear the thermostat click, but nothing else. Is there a reset or a fuse?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Checkout the co. webpage under troubleshooting the model #.
Posted on Sep 01, 2008
When air conditioner turns off out doors I can still hear it running in the attic.
Are you sure you are hearing the air conditioner running, or maybe just the blower? The blower may continue to run to further dry the evaporator core and reduce the chances of mold and mildew formation.
-Rod
Jun 03, 2017 | Heating & Cooling
Lights for fan and ac knobs out. Power outlet doesn't work. Where is fuse box?
On drivers side under dash ( by your knee's) there is a black panel that you remove for access to fuses up under there. You also have one under the hood on drivers side marked Fuse/relay, or power distribution.
Nov 23, 2011 | 1999 Plymouth Voyager
Filled Coolant reservior and radiator Drove trailblazer at highway speed no cooling problem. When slowed down in traffic temperature increased to about 220 and higher, could hear coolant bubbling in...
If there is bubbles occurring even inside the top part of the radiator (where you have the coolant put in), you may have a leak on your head gasket. You may be loosing coolant through the engine.
Sep 15, 2011 | 2004 Chevrolet TrailBlazer
Doesn't power up, test and reset buttons don't help. Using heavy duty extension cord,does it have to be plugged inj directly?
First, you want to make sure that you have power at the plug that you are using for your air conditioner. You can test it with a voltage meter or simply plug something else into the same outlet (if the receptacle is 220V, you will need to measure it with a voltage meter). If it works, you know you have power to the air conditioner. If it doesn't work, you'll need to check your fuse panel for any blown fuses or your circuit breaker box for any tripped circuit breakers.
Air Conditioner Control
If you have power, it could be one of several problems that are keeping it from running. Many times an air conditioner can't start the compressor if the amperage or voltage is too low. This can happen, especially if you run the unit from an extension cord or have something else that draws a lot of power on the same line. The compressor initially takes a lot of power to start.
Air Conditioner Switch
If you hear any odd noises coming from the unit, it could be the compressor trying to start, but unable to do so. Another part that causes odd noises is the overload/relay. This causes a click-buzz-click sound near the compressor. This is the overload/relay working, and it protects the compressor from damage by cutting power to it if there's a problem. If you hear this, the compressor has power, and it means something is wrong with the compressor. If the compressor is the cause of the problem, you'll need to contact a professional appliance repair person.
Air Conditioner Thermostat
Also, any of the control components could be the cause of your problem. These include the control board, the selector switch, and thermostat. The control board controls the overall operation of an air conditioner, and if it is bad, it may prevent the unit from operating. The selector switch is used to adjust the settings that you want on your air conditioner. The thermostat controls the temperature. In addition, the wiring between any of these components could be to blame.
Sometimes the plug for the unit gets burned on the end that goes into the outlet, or the outlet itself gets scorched. This will reduce the contact points and may not allow any or enough power through to operate the unit. If this is the case, you need to replace the plug and outlet as it is also a fire hazard. You may want to call a professional electrician for this job.
Jun 23, 2011 | Haier Heating & Cooling
Two winters ago i had to change out my thermostat. Then last summer my AC wouldn't turn on. So i thought it was the thermostat i had so i just went and bought a better one. but still the Fan on the AC...
If the compressors running and the fan is not you should check the fan motor capacitor and check for power at fan motor if power is there you have bad fan motor
Jun 21, 2011 | Heating & Cooling
The compressor fan come on; I can hear a clicking (the compressor trying to click on, then immediately shut off. It will contiula doing this as long as the thermostat is set for the ac to come on. I...
Possibly a bad run capacitor, have a service tech test it and replace if it is bad. That clicking you hear is the internal overload in your compressor clicking off on high heat/amp draw and then cooling down and resetting itself.
Jun 16, 2011 | Heating & Cooling
Need a cooling fan wiring diagram
Local Repair Shop
They should print what you need from
whatever data base they are using
May want a couple dollars,
get anything you can think of if
they seem helpful
May 28, 2011 | Acura Legend Cars & Trucks
I have 2 dometic ac model #630035.331 the back one will not start on any thing not even on fan. what could be the problem
1. with a tester check if there is power from the AC outlet
2. if there is, check the power in the AC unit
3. if none, check the built in breaker or switch, or fuse maybe blown.
4. reset overload protection if provided
Oct 18, 2009 | Dometic Rooftop RV Air Conditioner
I have a 1994 Carri-Lite 633RKS camper with electrical problems
The clicking your hearing from the AC is probably just the 12 volt side of the circuit to run the AC, but it does indicate that the controls/thermostat is doing it's job, but doesn't sound like hydro is getting to AC as well as microwave. I can't imagine those being on the same circuit as far as breaker panel goes, but who knows what might have been done before you got it, unless bought new. Do you by any chance own a plug in circuit/receptacle tester, or anything like that to test for power? In the meantime, make sure AC is in off mode, then go to breaker panel & push breakers for microwave & AC, all the way off hard, then try to reset it & tell me what happens.
Sep 04, 2009 | Coleman Heating & Cooling
Quasar HQ2051TH Air Conditioner Logo
102 people viewed this question
Top Quasar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
