Question about Haier Washing Machines
I just purchased a Haier HWD1000 washer dry combo. I set it up removed 3 bolts and leveled. During the spin cycle the machine shakes so bad that it scoots across the floor. I tryed putting some pads beneath the levelers. Is there something I'm not doing?
Put mine under the countertop where my dishwasher used to be. It shook around really bad in there, so I wedged a towel between top and counter, and also one on each side. That was enough to anchor it and it runs smooth and quiet. I am looking for something like a bean bag to free up my towels.
Posted on Sep 25, 2008
Water accumulates in drum when machine is off
it would suggest you have a leaky water inlet solenoid .
Oct 06, 2016 | Haier Hwd1000 1.7 Cu. Ft. White Washer &...
Had new machine deliverd today and it shakes real bad during its spin cycle, dont know what to do. i balance it . i notice 4 bolts in the back. some bolts stick out further than others
Most common problem is that the machine is not level. Each corner should have a leveling leg to lower of raise until the mahcine is level
Aug 27, 2011 | Amana NFW7300WW Washer
Spin cycle shakes whole washing machine
have you tightened the jamb nuts on the legs after leveling the machine so they can't move from where you set them initially when you leveled the unit?
Mar 21, 2010 | Kenmore HE2 Plus Front Load Washer
Shakes violently during spin cycle from back to
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
Mar 12, 2010 | Maytag NFW7200TW Front Load Washer
Washer will not stop shaking during spin cycles, we have removed akll shipping bolts
Place a load in the machine use a good level to get machine perfectly level. Now put machine on spin and check the feet. Find the one that is not solid and slowly adjust it until it stops shaking. PS place level on flat top surface and level side to side and front to back.
Jan 26, 2010 | LG Washing Machines
My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
Jun 11, 2009 | Haier HWD1000
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Hwd1000 washer dryer combo is not moving into the drying cycle
Its time you found out where your filter is to clean out thoroughly
Mar 02, 2009 | Haier HWD1000
Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Jan 31, 2009 | Haier HWD1000
Dryer Problem
EC4 The temperature of air vent
You need to call for repairs. Probably the heating element is faulty.
You can create a custom program without a dry cycle and hang dry your clothing.
Nov 21, 2008 | Haier HWD1000
Washing Machines Logo
143 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
