Question about Sony Mavica MVC-CD300 Digital Camera
Not happy with my CD300
Hi for a few month now I have been shooting pictures with my Sony CD300. All seems well when I'm outdoors with good light but as soon as I'm in the shade, or indoors and the light is low, the pictures seem to be either out of focus, or the pictures seem as if they were taken in a very low resolution and enlarged (many colored dots) etc... I'm guessing that it's probably me... I didn't see any complaints about shooting pictures in doors or in poor light conditions (not dark). Can someone point me in the right direction? thanks berber
    Master:
  • 551 Answers
The problem is in your ISO. The camera has a terrible noise problem at anything over 100 ISO. I set my camera to 100 even when shooting in auto, and never use any other ISO setting - the results are just not worth it. Hang in there. The camera is awesome and you will make friends with it. The settings are really not that complicated once you get used to them. Just decrease your shutter speed and increase your aperature (lowest number) when in low light conditions and watch the LCD until it looks good (you might have to half press the shutter to get a preview), until you get a bettter grasp of what those adjustments are doing for you. Good luck, Cindy
Posted on Sep 12, 2005
SOURCE:
My Sony Cyber-shot DSC-H9 has a problem when i'am using it outdoor, sunlight .Can shoot a picture, but screen dosen't display the area being photographed.
you must read the owner manual, section troubleshooting for indicate what is wrong. and fix it. Otherwise you must to the repair shop for fix it.
Normally the LCD is faulty, and need replace it.
God bless you
Sep 22, 2012 | Sony Cyber-shot DSC-H9 Digital Camera
Hand signal coming up when trying to take picture
The hand icon means you don't have enough light to take a hand-held photo. You need to either increase the light (take the photo in brighter light, such as outdoors in the sun), use flash, or a tripod.
Some cameras have a mode that will let you shoot anyway, but most people are not happy with the blurry photos they get when shooting when the camera warned them with the hand icon so you are better off not using that over-ride mode.
Dec 31, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Getting pictures loaded from mavica mvc cd300 camera to computer
Yours is a CD recording type. Shouldn't you just load the CD from the camera to the computer? Then cut and paste to a folder on your computer. Or copy and paste. Ed
Jan 23, 2008 | Sony Mavica MVC-CD300 Digital Camera
Pictures overexposed in daylight, visible lines in photos
1. Adjust ISO or ASA 100
2. Adjust AWB Indoor florescent or Bulb while outdoor select sunny or foggy it depends of the place
Dec 25, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Very Bright Outdoor Photos with lines
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open. You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
Mar 30, 2007 | Casio Exilim EX-S600 Digital Camera
Cd300 resetting default setting
Okie-tex, Why yes you can reset your cd300 back to the factory settings. On the bottom of the camera underneath the on and off button for your LCD is a little hole and it says reset next to it. Insert a straight pin into that hole and it will reset everything back to factory settings. Fellow Texan
Sep 13, 2005 | Sony Mavica MVC-CD300 Digital Camera
My New CD300!
EV stands for exposure value. An indication of 0EV is what the camera thinks the correct exposure should be. If the EV becomes a positive number it means the camera thinks the image is overexposed by that amount (+1=1 stop, +2=2 stops overexposed etc) A negative value means the camera thinks the image is under exposed. I have a 707 and find the I prefer the images from it at -0.3EV, so if you're happy with the setting you have now, I say stick with it.
Sep 12, 2005 | Sony Mavica MVC-CD300 Digital Camera
Mavica cd300
The camera is not megabytes (MB) but megapixel (MP), there is a big difference. If you multiply the horizontal resolution by the vertical resolution then that will be how many megapixels are being captured. So in this case, max resolution 2048 x 1536 = 3145728 which is 3.1 MP effective. I don't think any camera actually captures exactly the full MP listed on the camera. Now, if each pixel was represented by a byte then you would have 3.1 MegaByte picture captured. However, each pixel is represented by I think 3 bytes which would give you a 9.3 Megabyte picture captured. However, since this is usually to large for most users to deal with, compression is introduced thus the settings for fine and standard. The tiff picture type is the 9.3 Megabyte photo with no compression. For most of us this isn't very effective for working with so we use the jpg compression. This reduces the picture to a more manageable size for saving, manipulation and storing. Keep in mind that this is what is called a 'lossy' compression which means that it actually removes pixels from the photograph and uses a technique called interpolation to bring the pixels back later.
Oudoors with my Mavica....help!!!!
While it is no help for those with other cameras, Sony has fixed the problem with the FD91 which has a viewfinder that is not bothered by sunlight. The F505 LCD evidently works good in sunlight.
Sep 08, 2005 | Sony Mavica MVC-CD300 Digital Camera
IPhoto doesn't recognize Sony MVC CD300
Even though Sony Mavica digital cameras are listed as compatible with iPhoto, the camera has to be set to Picture-Transfer-Protocol (PTP) before you can download. In addition, you will need to open Image Capture in the Applications folder. As soon as these steps are taken, the camera is recognized by iPhoto and all photos downloaded into Image Capture.
Sony Mavica MVC-CD300 Digital Camera Logo
46 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
