Question about Maytag Neptune MAH5500B Front Load Washer
Neptune Washer dispensers
Machine was purchased 2005. Just had my first attempt to use the softener dispenser, but the diluted softener remained in its bin, plus the bleach bin was filled with water when the cyle concluded. Consulted the manual to confirm that the dispenser position and filling level are correct. This malfunction happens with the wash cycles and when 'extra rinse' is selected. When I ran 'Rinse' alone, it worked fine, both bins were empty at the end of that function.
Replace the wax motors for both the bleech and softener
Posted on Sep 03, 2008
Frigidare top loading washing machine, 1995 model # GLMS174SAS4
I believe the softener is dispensed through centrifugal force when the machine is in the high speed spin after draining and before filling for the rinse cycle. I had the same issue on another machine. Use very hot water and a washcloth to clean out the softener cup. When adding softener at the beginning of the load, only add the recommended amount and then fill the remainder of the cup with water.
Mar 06, 2015 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Where does the fabric softener and washing powder go in the LG WF-F5207PC 5.5KG top loading washing machine?
Put powdered detergent in the box at the back of the opening of the washer (opposite the control panel when the lid is open). If you use a liquid detergent, dilute it 1:1 with water and pour into the bleach dispenser at the front left of the washer. The fabric softener dispenser is near the bleach dispenser but a little closer to the tub and towards the middle of the left side of the unit. As with a liquid detergent, dilute 1:1 (30ml:30ml) with water before pouring into the dispenser.
If the fabric softener dispenser isn't working, add the fabric softener in the final rinse.
The manual for the washing machine is available here: http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-F5207PC-_E . You will need to review the unit or enter a security code.
I hope this helps.
Feb 13, 2011 | LG Washing Machines
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
Softener getting all over top rim of washer
i tell people to dilute it with water so it is not as thick.
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Maytag Neptune FAV6800AW - Fabric Softener dispenser doesn't empty
I had a similar problem with the fab. softener chamber. Clean
out the buildup and it will drain. To do this, remove the cap and wipe out the softener. Also, be sure to wipe inside the drum, just below the dispenser.
As for a water flow to the dispenser- You will need to remove the plastic portion of the lid. Start with the detergent dispenser, then gently remove the bottom corners of the lid. Then are held by two plastic clasps. Then gently remove the "L" shaped plastic holders. Use a pipe cleaner to clean out the tube where the water flows directly out of the unit, before entering the lid. I did this last night, and it works beautifully!
Jun 21, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
303 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
