Handle broke off cold water valve
Try to find them here Find the low cost Wholesalers Dropshippers on biggest wholesale place. Best of luck
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Also called ELITE Group and got a new tap sent to me for less than others are charging (even better than eBay). Just over $13
1-877-383-6399
I just replaced my cold dispenser tap with the white(neutral) after you drain your water jug down and empty and also the reservoir too....They just thread out . N ext time I will have to buy new ones , but they unthread very easy after the water is all drained.
Poor defective handles and then all these parts companies that are over charging for simple but also defective valves. Honest Abe would not allow such antics
if he were around today.
Model# ylr2-5-87h3
SOURCE: the plastic handles that dispense the water are broken
Where can I buy the spigets for a Sunbeam water cooler. I need one for hot and one for cold water. These handles are not strong enough plastic to last the lifetime of the unit. They should be made from metal. If the taps on our kitchen sink was made from plastic you can imagine how long they would last.
The handle on the hot water valve broke off.
I have a model 0100 with 3 taps and a refrigerated storage bottom. The cold water tap broke. where do I find a new one? How do you remove the old one? Thankyou
Sunbeam cold/roomtemp/hot water cooler, second time hot water handle has broken off. Other wise LOVE the unit has 5 gallon bottles & small frig underneath. Should come with spare hot handle or replaced free as defective.
handle broken on cold water tap
