Question about Yamaha RX-V1600 Receiver
YPAO mic I just bought a floor demo RX-V1600 at a steep discount , without remotes and the YPAO mic. Can I use ANY mic at all ( RadioShack) or , if not,ANY Yamaha YPAO mic for this set up?
  • Anonymous Dec 07, 2008
    I did the same thing just bought Yamaha v1800BL floor model at best buy no remote and mic wtf is it with best buy i work there lol and they throw away or loose damn remotes of floor models
5 Suggested Answers
jamo297
  • 19 Answers
SOURCE: RX-V1600 when i turn on no sound or channels display on
If you are sure that the speaker wiring is correct and connections are good, then:
  • Check the input and output connections are correct for each source.
  • Check that the input mode is not set to DTS or Analog - rotate the input selector to the source and the press the input mode, set it to Auto.
  • Also check that the front speakers to be used are selected A or B (or A+B).
  • If there is an optimiser microphone supplied with this receiver, ensure that it is not still plugged in.
Hope one of these solutions work for you.
Posted on Jul 19, 2009
firesnake09
  • 2923 Answers
SOURCE: Yamaha RX-V1600 shuts down in seconds
Your Yamaha RX-V1600 has an audio output transistors are mounted to a large heat sink which keeps them cool during operation. They are electrically isolated from touching the heat sink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set).
You need to check or replace the transistor that's on the heat sink. Or you may contact a pro to replace it for you.
Posted on Mar 14, 2010
jonsen
  • 62 Answers
SOURCE: RX V1600 HDMI outputs not working.Any ideas?
read the guide and call the company they can help !
Posted on Jun 10, 2010
dunnbiker
  • 8546 Answers
SOURCE: How to solve the the
Step 1: Get the manual out.
Step 2: Search it for W-1.
It's only a warning that the subwoofer phase is possibly reversed which can **** some of the bass out of the room at the microphone's position. If you CAN change the phasing, try it and retest. Otherwise repositioning the sub may yield a different result or it may just be a glitch.
Use a search engine and read up on speaker phasing.
Posted on Jun 28, 2011
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
Yamaha rx-v1600 hdmi output not working
Have you inspected the HDMI socket? I had the same problem and the socket had been damaged by a tight fit cabinet with insuficcient space behind the amplifier. A sideways cable tug on the inserted HDMI cable had snapped a small piece of plastic seperating the two rows of HDMI connectors, and three were splayed out, so no connection when plugged in. Solution was to carefully re-align the connector fingers and glue a tiny piece of insulating material between the two rows. The output now works perfectly. A bit fiddley, but worth the trouble when you look at how much Yamaha would charge to fit a new socket, or even a new board!
Don.
Aug 11, 2012 | Yamaha RX-V1600 Receiver
DirectV remote code for Yamaha RX-V1600 so I can control the volume
On DirecTv remote press MENU,
then Parental,Fav's & Settings "Select"
Go to System Setup "Select"
"Select" Remote in the left hand menu
Follow instructions to find your set or at least manufacturer's codes.
Oct 27, 2011 | Audio Players & Recorders
I'm looking to purchase a YPAO Optimizer Microphone. Can you help?
YPOA mics are not available in the end user markets, as they ship with the equipment. You should contact Yamaha directly to obtain ordering information. From the Yamaha USA Support Page:
If you do not know your part number(s), please contact us for assistance by dialing (888)-892-6242, Monday through Friday, from 7:30AM - 5:00PM Pacific Time (closed 12PM - 1PM).
Sep 06, 2011 | Yamaha RX-V863 Receiver
Jun 09, 2010 | Yamaha RX-V1600 Receiver
RX-V1600 2 clicks but won't switch on
I have the same problem, any resolution on this one yet?
Nov 13, 2009 | Yamaha RX-V1600 Receiver
Jul 19, 2009 | Yamaha RX-V1800
Yamaha RX-V1600 Receiver Logo
757 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
