Question about AEG 24 in. Favorit 50730W Free-standing Dishwasher
Powder solenoid I hav e an AEG Favorit 50700 sensorlogic dishwasher. As soon as I switch on, before even selecting a programme, the solenoid to operate the powder dispenser door operates, then stays activated until I remove power. I've taken the door liner off and the PCB looks OK - but I guess whatever powers up this solenoid has gone short circuit. Any idea what it might be or might look like?
The no-brainer answer is to replace the controller board. But I just saw the price on line was 248GBP ($350) which is not going to be worthwhile. I just had the same problem with the same model dishwasher. When I checked my circuit board under a microscope, I saw cracking and discoloration on what appears to be a ceramic capacitor. It looks like this capacitor is for snubbing the transient across the triac used to control the soap dispenser solenoid. I do not know what value this capacitor has, but I am about to replace it with a 47nF, 630V ceramic capacitor in a 1206 package. That costs $0.59 from digi-key (part number 445-8794-1-ND) I am sure that Colin999 has trashed his dishwasher by now since he posted his question over 4 years ago. I will post an update with the results when I get the part installed.
Posted on Feb 13, 2013
  • J. Frank Mortimer Feb 13, 2013
    It seems that I guessed correctly. The dishwasher is now fully operational. What most people are forced to do in situations like mine and that of Colin99 is to buy a new controller which costs nearly as much as a new dishwasher. In fact all that was needed was a $0.59 capacitor. Well not quite. My 30 years of experience in electronics allowed me to find the fault and guess the capacitance of the failed part. Better would be if all manufacturers provided full schematic diagrams. Then anyone with some basic tools could replace the broken part
    President:
  • 1,462 Answers
Probably the main module ie the pcb you were looking at
Posted on Sep 02, 2008
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Jul 31, 2009 | Dishwashers
My AEG favorit sensorlogic turbo dry dishwasher keeps bleeping and want start. Im not sure whats wrong with it. I have cleaned the filters and put in new salt and it still wont work. The programme...
hey
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Jun 09, 2008 | Dishwashers
Dishwasher fail on C3 (leak prevention system)
http://www.kunnig-elektro.de/reparatur/spuelen/aeg/zulauf2.html
in German ... anyway a couple of pictures :)
Dec 15, 2007 | AEG 24 in. Favorit 50730W Free-standing...
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
AEG 24 in. Favorit 50730W Free-standing Dishwasher Logo
778 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
