Question about KitchenAid KSB5 Professional Stainless Steel Work Top Blender
KITCHENAIDE BLENDER I was blending bread and bagels to make bread crumbs. All was well until the blender stopped blending. It was running, and the blade turns when it is empty, it is not chopping, pureeing, liquifying, crushing, or blending anything! Any suggestions would be much appreciated!
  • 89 Answers
Sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Posted on Sep 01, 2008
Best blender brand for smoothies and juicing?
I would recommend to invest in a high quality blender that can perform all blending operations. If you're going to blending a bunch and need high speed blender to prepare smoothies and juices quickly. Vitamix will be a great option.
GroomNStyle Best Kitchen Blender Reviews 2015
Jul 29, 2015 | Blenders
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
Waring blender shoots food out the top
Are you blending something hot? When you blend a hot item the steam that is released will increase the pressure in the headspace above the contents in the blender. The lid will eventually blow off to release the pressure.
To avoid this problem begin blending with no more that one cup of ingredients. Before turning the blender on, remove the center lid insert to allow venting of steam. Blend on low speed. As you blend you can add another 1 1/2 cups of additional liquid through the opening in the lid.
Trust this method will resolve your problem.
Oct 22, 2011 | Waring 6000CG 60th Anniversary Blender
How can I change the blade for my 2 speed hand mixer? The model type is NC-12 if you need to know
you are using your KitchenAid blender and it stops blending, you may think there is a problem with the motor in your machine. However, a common reason for the blades not rotating in the blender is a dirty or faulty coupler. The coupler is what connects your blender dispenser to the motor, and you can easily replace the coupler at any time by only using a screwdriver.
Things You'll Need
  • Flat-blade screwdriver
    • 1 Turn the blender dispenser clockwise and lift up to remove it. Set the blender dispenser aside.
    • 2 Insert a flat-blade screwdriver between the black drive coupler and the frame of the blender on the top center portion of the blender.
    • 3 Lift the screwdriver upward, and the coupler will start to bend out of place. Slightly turn the coupler and then lift up on the screwdriver again.
    • 4 Continue to move the coupler slightly and lift the screwdriver until the coupler is completely removed.
    • 5 Insert the new coupler over the blender's motor blade and then twist the coupler counter-clockwise until it is tightly fastened.
Jun 07, 2011 | Blenders
The pulse light is blinking, but the blender will not work
This worked for me - only took about 5 minutes (the amount of time it took for me to google Black & Decker and search through their FAQ)
Q. My blender stopped in the middle of blending. What happened?
A. Your blender has a motor overheat protection system that will automatically shut off the blender when it has been running too long with a heavy load. If this happens, unplug the blender and wait 10-15 minutes to allow the motor to cool down. Plug in the blender and resume blending.
May 28, 2010 | Black & Decker BL1900R Blender
My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Oct 06, 2009 | Kenmore Blender Single-Speed Blender
Westinghouse inteliblender
Mine developed the same problem except it stopped blending while I was using it. Being an electrician I opened mine up and put a meter on the motor windings and found that the windings were open. So basically the motor is shot...unless you can find a part number for motor replacement or if your's is still under a warranty...it might just be easier to buy a new blender.
Sep 27, 2008 | Westinghouse 0101 IntelliBLEND¿ Work...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
KitchenAid KSB5 Professional Stainless Steel Work Top Blender Logo
218 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
