Question about HP Jornada 547
Jornada 547 rebooting W2000 E-PC
I have a Joranada that sporatically reboots an E-PC when inserting or removing from the USB cradle. Then the USB ports are disabled till you unplug the E-PC. Doesn't do it via serial cable. Sent Joranada in for repair. Replaced cradle. Loaded Active Sync 3.5 Any ideas or anybody with the same problem?
    Master:
  • 450 Answers
There is a patch/hotfix out from MS for this: 252795 wich cures that problem and adds the IrCOMM protocol to your Windows2000 (it was missing there before).
Posted on Sep 12, 2005
EMachines 270 rebooting whenever new USB inserted
sounds like you have a short circuit try a diffferant usb port or a usb extension
Feb 11, 2012 | eMachines Computers & Internet
I have a C-3030ZOOM. Had a HD failure and re-instaled CM 2.01 and updated to V2.3 that is running MS OS XP Pro. The computer is unable to recognize camera. When I connect the camer to PC via USB - I do...
Presumably you downloaded this, extracted files and right clicked inf file and clicked install? Did you then reboot and try to connect the camera? Connect then switch camera on?
Jan 03, 2011 | Olympus Camedia C-3030 Zoom Digital Camera
I have a Jornada 680. My screen is blank even after changing the back up battery and performing both a soft reboot and a hard reboot.
It could possbily be a loose connector or more likely its a broken flexi PCA. You could try swapping the screens with another Jornada, by buying a faulty one off of ebay that doesn't have a faulty screen.
Apr 30, 2009 | Computers & Internet
Jornada 547/548
When you smell burning silicon thats a sure sign you are going to need a new one. Sounds like some pretty severe damage to chips if it smelled up the whole car. But the battery charging light still working is a good sign, which means its not a total loss.
Sep 12, 2005 | HP Jornada 548 Pocket PC
Jornada 568 Sync Problems
All you have to do: Select Device Manager, select "Universal Serial Bus controlled". Re-install the USB driver from Active-Sync CD. That's it.
Sep 12, 2005 | HP Jornada 568 Pocket PC
Jornada 565 no longer being seen by ActiveSync?
Occasionally under XP Pro, my 564 won't be recognized when I put it on the cradle to sync. I just take it off the cradle and try again. My understanding is the XP loads an HP driver when the Jornada is detected as connected by USB, if that driver doesn't load succesfully, then XP won't recognize the Jornada.
Sep 12, 2005 | HP Jornada 565 Pocket PC
No valid Windows Ce application on Jornada 545
I use an Omnibook 500 with a Jornada 545 as you describe without problems. The most likely cause is the difference in processors. The first version of Pocket PC was supported on three different CPU architectures. The Jornada 545 uses an SH3 processor. Applications designed for the 565 will not run on the 545. You will need to find applications designed for the SH3 processor.
Sep 12, 2005 | HP Jornada 545 Pocket PC
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
EM-500 sync problem
There have been issues with the cradle PCB on the EM-500. Casio has redesigned the same added an IC & a few additional componentes. I had similar problems & simply could not connect through the USB port. Worked flawlessly with the accessory serial cable (direct connection - no cradle ). This also was on an XP system. See if you can wangle out a free replacement/fix for yout cradle from Casio.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
HP Jornada 547 Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
