Question about JVC Cameras
I have a JVC GR-D30U I get error E)$ eject and reinsert tape unit in safe mode. I can not eject the tape to reinsert it.
  • rdroten Sep 01, 2008
    JVC GR-D30U Digital Video Camera error E04 eject and reinsert tape in saftguard mode. Will not eject tape. I tried forcing it open which did not work.
    I wasted my time and money.
  • 2,071 Answers
Just open your digital camera try to look for a misalignment,or worn out gear or spring is loose,this a mechanical problem..
Hope this may help;
Regards,
VOTIT
Posted on Sep 01, 2008
  • 6,487 Answers
This is a mechanical problem with this JVC GR-D30U that alot of user are also having problem , what I can suggest you to do with this is to take it to JVC service center and hopefully they can fix it since alot of problem are reported with this type of device and it ended up being replace....
Good luck............
    Genius:
  • 1,269 Answers
Try to turn it off and unplug the power cable for 5 mins. Then try to eject again.
  • Michael Galve
    Michael Galve Sep 01, 2008
    I mean unplug the battery source for 5 mins then put back in.
    Brigadier General:
  • 3,614 Answers
Have u try to forcely removed the cover to takeoff the tape inside
    Genius:
  • 3,422 Answers
HI,
Please reset it.By removing the battery for 10min and then insert it back.Let me know the result.
  • Priya darshan Sep 01, 2008
    Can you please tell me the right error?Is it E04 or E02 or E03?
2 Suggested Answers
SOURCE: JVC GR-D30U Digital Video Camera error E04
I have a DVL25L Mini Digital Camera. Once it switch on LCD Display on & get stuck & showing error code " E01" Need youall support to solve this issue. Thanks,
Posted on Mar 24, 2014
My JVC GR-D32 keeps saying unit in safeguard mode eject and reinsert tape. E04. Have done everything whit out succes.
Use a hair dryer heater into the opening tray to warm up the inside. It is possible that the DEW SWITCH is triggered and so the system goes to safe mode so that it does not entange if moisture is present on the drum. If not there are errors on the servo section and can be a failure on the board.
Jul 13, 2011 | JVC Video Cameras
How to remove safegaurde mode in GR-D239E
I stumbled upon this solution to your question:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
In neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
I hope that helps.
Jul 07, 2009 | JVC GR-D30U Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
there was a hole under the tape deck.. u can try to force;y open it right there
Sep 01, 2008 | Cameras
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Cameras Logo
158 people viewed this question
Top JVC Cameras Experts
Parshiv Luthra
Michael Galve
Michael Galve
Are you a JVC Camera Expert? Answer questions, earn points and help others
