Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch dishwasher arms dont spin, but turn freely
Soundsike watre is running, but the arms havent moved
How do you know the arms are not moving? They are spun by the water jetting through them and they may be blocked. They just pull out and clip back in so run some mains water through them. Also if you put dishes or trays that are big they can obstruct the arms so give them a spin to see first.
Posted on Sep 05, 2008
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Spray arm not turning on Bosch Tabletop S2R1B
The inside of the arms can get blocked, only if the water can move freely through them do they turn, cause by the water ejecting from the arms spay holes. Lift or pop the arm off its mount, its a push-click fit.
have a look inside it for debris like chicken bones and clean it out.
do the same for the socket the arm came off -check all tubes are clear.
Dec 14, 2013 | Bosch Dishwashers
The bottom spray arm of my bosch dishwasher will not spin. Nothing is blocking it, spins freely if you spin it by hand. We've tried resetting machine via control panel and also by circuit breaker, this...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
After the dishwasher runs there is a lot of soap left in the soap dispenser. I've tried powder and liquid. Liquid is a bit better. I've tried using less soap but there still is a lot left. Also my glasses...
With the LG LDF6810 model, this is not a common problem. Please try the following test, With and empty dishwasher, add a small to normal amount of dry dishwasher powder and run an (empty) load.
Check to see if any soap remains in the dispenser cup.
If any remains, here are three things to do: 1.) Upgrade your dishwasher detergent to a name brand powder (e.g.: Electrosol or Cascade)
2.) When you load the dishwasher, do not place large items in the front, near the door/soap dispenser.
3.) Before you load the dirty dishes for the next several loads, with your hand, turn both the upper and lower wash arms so they point at the door. Load as you normally do and push the racks fully in. Before you close the door, spin both the upper and lower arms and confirm that they spin freely and neither hits anything. if either does not spin freely, pull out the rack and arrange so the arms can spin freely.
I find that the only time I have left over detergent powder is when the wash arms do not spin freely.
This is a common problem on most every energy star/water conserving dishwashers.
Please report back what you find, OK?
May 21, 2010 | LG LDF6810ST Stainless Steel Built-in...
Top Wash Arm not Spinning
water is not circlating, you need a circulation pump
Feb 24, 2010 | Bosch 24 in. SHV55M03GB Built-In...
I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes not getting clean. have cleaned out the parts in the bottom and run it empty
Raise your water heater temperature to 140 degrees.
Use FINISH TABLETS
If wash arms don't spin freely when dry, there are repair kits available.
Dec 20, 2009 | Bosch 24 in. SHX33A05 Stainless Steel...
I have an equator PLS600 and I can't seem to get it to work. I have tried the WikiFix to help a stalled dishwasher, by adding water and vinegar. When I put on the wash cycle it does not run. Even with the...
Give the spray arm a spin to make sure it rotates. It should spin freely. If not, remove plastic spray arm clip, flip it over, replace it, and try again. Make sure holes in the spray arm are clear of debris. Spray arm must be clean for it to spin. If spray arm does spin freely, remove spray arm clip, spray arm and the post assy (the thing the spray arm attaches to). Try your WikiFix again. This time add baking soda to the hole the post assy came from. Top it off with white vinegar. Leave it overnight. In the morning, stick your finger down the hole where the spray arm assy sat. You should feel a plastic thing. This is a propeller attached to the recirculation pump. You need to free it up. Get that thing moving with your pinky or a chopstick or whatever. Try the machine without the spray arm. You should get water blasting up from the hole. Reassemble the spray arm.
Nov 26, 2008 | Equator 20 in. PLS600 Free-Standing...
Top blade not turning
does it turn freely??
like if you give it a swind does it take about 6 revolutions then slows and stops?
if it does unscrew it (silver screw) and check the holes and washers and screws etc... as they can break perish.. if you dont know what to look for here i a tip!!
go snooping at any respectable white goods store, find the same model that you have and pretend to examin it lol! look at its top arm and see if it mooves as freely as yours!!!!!!
and for same parts etc.. anyhow the point is that if it moves freely then when the pump goes on the water should force it to spin smoothly!
however. get your self some dishwasher cleaner!
for the dishwasher! not the dishes! it is like a drain-o for dishes! it unclogs and un clags the pipes etc...
good luck!
Oct 13, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher
If you coud describe where you hear the noise that would be helpfull. the noise could be somethig hilling one of the spray arms or something stuck in the pump impeller. if you only wear it when it is only in a wash cycle I would say it may be someting in the wash pump. But also make sure the spray arms are moving freely
Jul 19, 2007 | Bosch 24 in. SHV66A03 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
144 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
