Samsung DLP HL-P5663W 56" TV Logo
Posted on Jul 31, 2011
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the back to c what it does. the fans turn on and the lamp light flashes then the tv turns off and the lamp light stops and so do fans. and then the the stand by/temp light flashes red and the lamp light flashes green.
  • Anonymous Mar 17, 2014
    Not working
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Aug 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
8261
Points
23
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
I don't have the manual for my Samsung DLP projection T. V. but my stand by/temp red light blinking come on then go off, along with the timer green light come on please tell me why i do not h
Samsung= Lamp is customer replaceable-----Google the HLS5086 (forget the WX etc) for "manual" and if you remove the lamp(very easy) look to see if the lamp is shattered inside---
You Tube has lots of videos by model and brand for lamp removal and replacement--if you need advice about this leave a comment here.
My sanding tv hlt4675sx xaa keeps turning off. When I turn it back on here a little grinding noise... now when I turn it on can here the fans come on nothing else. No light from the bulb is showing from...
It sounds like the color wheel has fallen apart. I would recommend calling Samsung at 1-800-samsung to find the closest service center. This can be a difficult repair and I would strongly recommend a Samsung authorized repair center.
2helpful
2answers
My hlt4675sx/xaa won't power up. The Stand by/ temp light and the lamp light flash. The bulb id brand new.
First thing to do is look from back of set or area when lamp is: do you see the lamp come on for even a few seconds?
Also is the problem the exact same as before lamp Replaced?
Before set failed did you hear unusual fan like, high pitched whine or even grinding sound?
Depending on how you answer I will assist you.
SD TECH
3helpful
Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
6helpful
2answers
I have a Samsung HLS4266WX/XAA that keeps turning itself off with the red stand by/temp light on in the front. I have allowed it to cool down for over an hour with a box fan pointed on the back of the...
Dear dreadtrainer;
It sounds like your Lamp is going bad. The part # B96-01472A. Go to internet (like Google), enter Model # and Lamp toget your best price. To replace the lamp is easy, look at your 'owner's manual".
Good luck, Big Irish.
7helpful
2answers
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
