Question about Philips Televison & Video
Dear Sir, I have just purchased two Philips DTR 2520 set top boxes, one for the bedroom working fine. The other one I require your help please, I own a Panasonic 37" digital plasma TV, a Panasonic DMR-E85H DVD Video Recorder (HDD DVD Analogue) Also an LG LV880 VHS VCR Analogue. If possible I would like to connect the above items together which would give me more flexible recording and in digital. Many thanks for your time and any help that you may be able to give. Regards Alan May
  • tasmin Sep 03, 2008
    Thank you for your time and any effort. But i have solved the above problem myself.
    Many thanks
    tasmin
  • 1,879 Answers
Connect the Philips DTR 2520 & LG LV880 VHS VCR Analogue to the Panasonic DMR-E85H DVD Video Recorder then connect the Video Recorder to the Panasonic 37 Plasma.
Posted on Sep 01, 2008
  • 10,594 Answers
Please connect Philips DTR2520 in Panasonic input and confirm its result on TV, now connect TV Monitor Out to Panasonic DMR-E85H dvd recorder for digital recording purpose, connect dvd recorder output to LG LV880 VHS VCR input for analog recording on VHS Cassette.
VHS VCR output will be connected to TV input 2 to view its Playback.
Need further assitance, please let me know.
    Master:
  • 763 Answers
Try to read this sir and hope that would help you
http://hometheater.about.com/od/dvdbasics/a/dvdvcrconnect.htm
ill look for another solution
cheers
CHARCOIS
    Brigadier General:
  • 3,614 Answers
So you want all device connected to each other, right?
Hi, I've connected a Philips 42PF9946/79 Plasma TV to a Beyonwiz DP-Lite i Digital Set Top Box. The connection is through a HDMI Cable and TV is viewed on the 'HD' channel/mode. Previous to the Beyonwiz...
@leemcdowall...
your concern points to some adjustments of resolution from your set top box, as we all know all TV'S has fixed resolution doesnt matter what brand and the only way you can change that is through your source which in this set up is your Beyonwiz, please consult their manual and see if you can change the resolution in their video set up page.
Feb 20, 2011 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Sep 30, 2009 | Philips Televison & Video
Philips 21RF vardaan there is no sound but everything works fine
buy a remote for rs 100 . select the AV button on the remote .
May 27, 2009 | Philips 32PW6506 32" TV
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Just installed new tvonics250 freeview + box
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
Mar 02, 2009 | TVonics Televison & Video
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Philips freeview box DTR 220
Same problem with Channel 71 CBeebies. Tried rescanning which worked initially for a few weeks but it's back and rescanning does not fix the problem now.
Feb 14, 2008 | Televison & Video
Philips DTR 200/05 Freeview box
Could be box power supply failure
Oct 20, 2017 | Philips Televison & Video
Televison & Video Logo
340 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
