Question about Archos Computers & Internet
Archos 605 I have accidently formatted my hard drive and lost all the pre-loaded information can i reload this somehow.
  • 26 Answers
Hi
you can use data recovery tools. one of them is microsoft undelete.
Posted on Sep 01, 2008
My archos 605 wifi media player when turned on,says fat is corrupted.what is te problem
Hard Drive Needs to be Formatted!!!!!! Just Plug in the device, Go to My Computer, Right Click on ur device and format it, But before doing this make sure you back up the data if there is anything because formatting the Player would erase the data on It!!!!
Dec 29, 2011 | Archos 605 Wifi Portable Multimedia Player
Coe 102
Your post/description indicates a possible problem with the firmware. It would seem that the Archos 6052_bing.gif would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
There are several versions of the 605, you need to determine which one you have.
Things you can try:
1. Do a soft reset. Press on the power button for about 15 seconds;
2. Do a full/hard reset by removing the batteries and pressing the master reset button;
3. Try again the Systems Recovery. You may need also to format the internal HD but that would mean you loose whatever data is inside.
Alternately, you may need to update/re-install the firmware. A more complete and better explained firmware update procedures are here. Briefly, you have to download and save in your PC the ???????.aos file (there are several versions of the firmware. You need to determine which one is appropriate to your model), connect your 605 to the PC, copy/paste (drag & drop) the said file to the Archos device listed in "My Computer" (you may have to overwrite the older copy), disconnect 605, proceed to System Settings, tap on "Update Firmware". Follow on screen instructions.
If the above is not corrective, am afraid that your unit has been partially bricked. Some have reported serious hardware or firmware problems with the 605 that would require replacement by the manufacturer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 12, 2010 | Archos 405 Digital Media Player
Fix my archos 605 wifi 80 gb please
I sen't you a solution didn't you get it?
If your archos 605 is in recovery mode I beleave the firmware(software) would need to be reloaded.
Here is the firmware for the 4GB version of the device, the page has instructions on how to load the firmware. Click on "how to install firmware" for step by step instructions.
4GB version here
http://www.archos.com/support/support_tech/updates.html?country=global&lang=en
20GB-160GB version here
Mar 06, 2009 | Archos 605 Digital Media Player
Formating archos 605 wifi
If I remember correct, then when I updated my Archos by hard reformat you have to request Archos resend the plug-ins, as long as you have the reciept or email.
Jan 30, 2009 | Archos 605 WiFi Digital Media Player
I cant access my files when I plug my Archos 605 into a computer!
i had the same problem what i did was i downgraded my 605 to
Archos 605 Wifi (20GB-160GB) OS v 2.0.10
then i upgraded to Archos 605 Wifi (20GB-160GB) OS v 2.1.04
heres the link for 2.0.10 http://update.archos.com/5/a605/a605_r2.0.10/firmware_a605.aos
and heres the link for 2.1.04 http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
Jan 01, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 wi /fi only puts music on hard drive
A couple things to note. First.
Make sure the files are the right format.
second, make sure they are in the music folder.
third... sometimes it won't read them. you can still play them here's how:
Go on your archos go to music, than at the bottom click on hard drive.... you can play everything there.... i recommend not synching it... but dragging and dropping them in by hand... i like doing things basic...
Dec 24, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 Wifi . Can't Write To Drive
Make sure when you format archos its in file system fat32. I can only assume you need check folder permissions, which is why you cannot write to drive.
Mar 10, 2008 | Archos 605 WiFi Digital Media Player
Recovery code 102
Your post/description indicates a possible problem with the firmware. It would seem that the Archos 605 would load but fail to finish and there restarts itself. This could only be possible if somehow the firmware has been corrupted or you tried a firmware upgrade but failed halfway.
Things you can try:
Feb 24, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 Recovery code 108
1. Download the latest firmware from Archos
2. Format the drive on your player
3. Connect the A605 to your computer using the USB lead
4. Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
5. Click ok and you are finished
Feb 18, 2008 | Archos 605 WiFi Digital Media Player
Computers & Internet Logo
119 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
