New alpine speakers just stopped working on one side of my car and don't know what to do
  • 2,071 Answers
Just check the wiring connection from receiver to your speaker,try to interchanges the left and right or to one side and to other side,so we know that the speaker is the problem .If happens still only one side is working even you interchange,then the problem is the speaker. If happens the speaker from left to right is working then the right to left is not works then the problem is the one side of the amplifier section is defected maybe the IC chip is busted or just loose,crack or cold solder joint.If cold solder only then reworks the solder joints in amplifier section.Then if the speaker is defected just reworks the solder connection of the speaker only .If still not working even you resolder the speaker then thats is the time you replaced the speaker...
Hope this may help;
Regards,
VOTIT
DON'T FORGE TO RATE;
Posted on Sep 01, 2008
Alpine Ipod Interface Not Working Correctly
Sometimes those 3.5 mm stereo connectors don't work right. If a little wiggling and unplugging/replugging does not restore the sound there may be a connector that is defective
May 05, 2013 | Alpine Kca-420i Kca-121b Ai-net3.5mm Mp3...
I changed my battery on my Ody Honda 2007 and the radio and clock are not working how do I correct this problem
I have 2002 Honda Ody and went thru battery hell and cost of replacing new batteries just to find out that the cheap radio CD player was shorting and rappidly draining all the batteries. The solution for me was install a $120.00 Alpine radio and replace all stock speakers with matching Alpine speakers. It will turn your Van into (The Alpine Room ) This stops the battery problem and the quaility of the sound system makes you forget the hell you went thru and also not hate Honda so much for putting the cheapest radio they could find in a $ 32,000 dollar vehicle.
Dec 10, 2010 | 2007 Honda Odyssey
Whats the best alpine 6x9? dds-r69g,sps-6939,spr or others
All of these work nice, remember the quality of the sound depends primarily on the source ( car stereo and/amp) and then the speakers, you need to know what Ohm and what watt is the minimum requirement for your sound system.
Feb 07, 2010 | Alpine DDS-R69G Car Speaker
Alpine sub works for a bit then stops.
the amp maybe going into protect mode. it may be seeing a fault internal and causing this. so i would have to say check all the wiring over and if that is okay you will need to take the amp for repair
Feb 01, 2010 | Car Audio & Video
I'm not getting the correct output from my door speaker only on the left side. was told it is my alpine deck (one of the channels went out)
Definitely possible. To make sure it's not your speakers switch the wiring for them. Basically change it so the side that is working now is connected to the speaker that is not working. If it works then it is your Deck.
Oct 10, 2009 | Alpine CDA-9825 CD Player
Don t have a problem but i need a diagram how to wire a alpine cda-985 reciever to a kenwood kac-x542 amp in a 74 corvette
how to fit an indirect hot water cylinder from off an rayburn royal .and is it possible to use a pressure cylinder . diagrams would be useful please.
curt
Sep 22, 2009 | Alpine Car Audio & Video
Subwoofer stopped working
Put another known working speaker in there to see if it works. If it does then the issue is with your speaker. If it also does not work your amp is to blame.
Sep 16, 2017 | Alpine SWR-1222D 12" Type-R Series...
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
90 people viewed this question
 Grubhead
Grubhead
