Question about Durabrand STS92 System
Home Theater System
I had this system for about 3 or 4 months now. All speakers work except the one you hear the voices on. The connector to the middle speaker came out of the yellow connector that connects to the DVD player. I have the Durabrand STS96. The area where I have to type in the product is not listed. I bought this system at Wal-Mart. I wanted know is what is warranty for this product since I only had it for short amount of time? Would I need to replace the whole speaker or can I get a replacement part for it?
  • Anonymous Sep 17, 2008
    have have the same problem
  • Durabrand Master
  • 5,568 Answers
Your system was manufactured by Funai which also rebrands several other 'house brands' such as Symphonic from K-Mart, and also sells consumer stuff under its own name.
Too many warranties run only 90 days now, so if the information on warranty coverage is not toward the back of your user guide or you no longer have it, you can download a copy here:
http://www.funai-corp.com/support/manuals.aspx
The track record of Funai-built products has not been very good.
BTW, I hope you have your original receipt; Wal-mart is becoming a stickler for this since they seem to have a number of junk brands breaking down; I own one of them.
Posted on Sep 01, 2008
  • 535 Answers
If u r in warrenty then company give u replacemant
UBX Home Theater System
It sounds like a problem with your centre channel or speaker. The sound of Voices and on-screen, actions in the middle of the screen are played through the centre speaker. General sounds such as music in the background, off-screen events, etc. will be played through other speakers on a home theatre system. Check your connectors coming from your DVD player to your sound system. Are you using a single-cabled digital connector or one for every channel? Check your sound settings as well, i.e., Surround, AC3, Music, etc.
Jan 30, 2014 | Audio Players & Recorders
When a movie is playing, you can hear all sounds except the actors voices....they are mumbled.
The voices are probably coming out on one of the channels that has a bad speaker, bad wire, loose connector, or bad output. If you have the audio set to 5.1 output, change it to two-channel stereo output. The voices should return to normal.
Nov 03, 2013 | Samsung HT-Q70 Home Theater System System
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
Sony Home Theater System DAV-HDX277WC - I get sound and video when playing a DVD, but no voices. Tried many different movies. Any suggestions would be appreciated.
Verify that all speakers work for test tones first. The center carries most of the dialog. It's in the manual, as is your symptom (page 101).
May 21, 2011 | Sony BRAVIA® DAV-HDX277WC Theater System...
Sound problems
panasonic sa th-440 f61
Aug 18, 2009 | Venturer STS152 System
No vocals
All voice will come out of the centre speaker, check this by swapping with another speaker, and then in the menu check that it is 'on'
Aug 05, 2009 | JVC TH-G30 Theater System
When watching a DVD, the surround sound plays all background music but the actors voices are not heard - can hear music and voices in 2 speaker only - TV programs play in 2, 3, and 5 speaker mode.
If there is nothing at all from the center channel while watching a DVD, first try resetting the system (unplug the power cord from the sub, and the DC power cord from the media center for 30+ seconds) If a reset doesn't help this, run the "adaptIQ" setup disc again. Honestly, this is a very odd problem for that system to have. (especially since we know the center speaker works for other sources) I hope this helps.
Jun 20, 2009 | Bose Lifestyle 28 System
Sound from DVDs
check the centre speaker is wired right
Jun 27, 2008 | Audio Players & Recorders
No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Mar 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Durabrand STS92 System Logo
102 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
