Question about Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television
Mitsubishi WT-42313 TV
I have a problem with my TV not powering on. It clicks and lights green on indicator but then clicks off and stays black on screen. It won't power up at all.
Did you get yours fixed?
  • 2 more comments
  • dgish Nov 02, 2008
    I have the same problem. I've determined the 5A -24v fuse on the main power supply board is blown; the rectifier diode shows evidence of getting hot, so I assume there's a high current problem, probably over on the main high voltage board. Looking for a schematic.
  • sfollese Feb 23, 2009
    Mr dgish had the correct solution, the fuse is not easy to identify for a novice, it looks like a a resistor that is green and is soldered into the circuit board for the power supply F9A03 and or F9A05.
    It was very helpful, the fuse had blown as well.
    You will need equipment for de-soldering components to get the old parts off of the circuit board.
  • Anonymous Mar 18, 2009
    HOw do you know if the fuse is bad? The little green ones. I have the same problem and I have located the fuses, but cannot tell if they are bad. Also, how do you know if the IC is bad?
  • hakreiter Mar 18, 2009
    HOw do you know if the fuse is bad? The little green ones. I have the same problem but cannot tell if they are bad. Also, how do you know if the IC is bad?
I found the schematic (downloadable PDF) for $7.99 at http://www.completeservicemanuals.com. Cheapest I found and highly recommended.
The blown fuse was due to a fried convergence IC. There are two of these on the high voltage board; they should be replaced together as a matched set. The bad one had gotten so hot I only had to unsolder three pins -- the rest were already loose!
I found the ICs at http://www.electronic-repair-kits.com, also highly recommended. The correct part for the WT-42313 is STK394-250. Make sure you order a pair and they will send you a matched set.
My set is now operating; I just need to clean the optics and do a convergence alignment.
Posted on Nov 18, 2008
  • dgish Nov 18, 2008
    BTW, I also found the 5A Pico fuse at www.electronic-repair-kits.com. The only other thing I needed was heatsink compound, which I picked up at Radio Shack for $2.99. Be sure to clean off all the old heatsink compound before applying the new stuff.
    Total repair cost including manual, chips, fuse and heatsink paste: about $50.
Mine was a power converter/supply issue. I took it in and 300$ later it was as good as new.
Posted on Nov 13, 2008
WT-42313 - Won't turn on. TV gives and error code of 24. I found that this is an issue with vertical deflection. I need to know how to repair this issue.
Ck pico fuse F9A05 5amps it will be green or yellow looks like resistor if bad, replace Both STK ICs STK394-250 and 2 resistors R8c13 &14 3.9ohms also resolder all 3 yoke plugins on board.
Sep 20, 2009 | Mitsubishi WT-42313 42" Rear Projection...
My TV not powering on. It clicks and power lightgoes green, then
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 06, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Power on 2 sec. then off won't turn mitsubishi wt-42313
with this model there may be a liquid spill on the signal board this is because one of the tubes is leaking
Jun 17, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Power light for 2 seconds, then nothing:
send me d model number and i could help most likely u have a powersupply problem
Apr 07, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Turning on my tv set
Same issue - our successful fix, at least temporarily, is to unplug power cable from outlet for at LEAST 4 hours...pref. overnight.
Jul 15, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi WT-42313 color problem
see if this helps you out
http://www.digitalhome.ca/forum/showthread.php?t=21847
Dec 03, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42313 42" Rear Projection HDTV-Ready Television Logo
403 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
