Question about Sony Mavica MVC-CD300 Digital Camera
Error Mavica CD300
Hi I have a Mavica Sony CD300 one and a half year ago, and two weeks ago the camera give me the following aleatory error: "DRIVE ERROR C:32:01" I poweroff and poweron and then I can continue to take photos. Anyone have any idea? Thanks
vega
  • 551 Answers
SOURCE: Mavica cd300
The camera is not megabytes (MB) but megapixel (MP), there is a big difference. If you multiply the horizontal resolution by the vertical resolution then that will be how many megapixels are being captured. So in this case, max resolution 2048 x 1536 = 3145728 which is 3.1 MP effective. I don't think any camera actually captures exactly the full MP listed on the camera. Now, if each pixel was represented by a byte then you would have 3.1 MegaByte picture captured. However, each pixel is represented by I think 3 bytes which would give you a 9.3 Megabyte picture captured. However, since this is usually to large for most users to deal with, compression is introduced thus the settings for fine and standard. The tiff picture type is the 9.3 Megabyte photo with no compression. For most of us this isn't very effective for working with so we use the jpg compression. This reduces the picture to a more manageable size for saving, manipulation and storing. Keep in mind that this is what is called a 'lossy' compression which means that it actually removes pixels from the photograph and uses a technique called interpolation to bring the pixels back later.
Posted on Sep 12, 2005
jackboy
  • 2985 Answers
SOURCE: Sony Mavica MVC-73
This is an early floppy drive model yes? Drive error could refer to corrupt floppy disc or a failure of the drive. Check the disc angle first - new disk formatted to camera. If it is not that - then buy another camera A repair I guess will not be an option -but checkout Sony first.
Posted on Sep 13, 2007
Eggman23
  • 20 Answers
SOURCE: getting pictures loaded from mavica mvc cd300 camera to computer
Yours is a CD recording type. Shouldn't you just load the CD from the camera to the computer? Then cut and paste to a folder on your computer. Or copy and paste. Ed
Posted on Feb 07, 2008
Agent Allan
  • 480 Answers
SOURCE: sony mavica trouble reading discs
Hey jadyjo,
You need to format the floppy disc by selecting file, then disc tool, and then format in the menu system. Instructions on how to do this are on page 52 of your user manual. Remember that formatting the disc will erase any images on it even protected ones. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 13, 2008
SOURCE: mavica mvc-300 disc error c:13:01
I have had similar problem and i think it's a problem with the disc. Make sure the disk is clean and unscratched. Check your other discs, too, to see if they are giving you the same problem. If not, it' is most likely the disc and not the camera.
Posted on Jul 25, 2009
  • 6771 Answers
SOURCE: Hi- I dropped my Sony
From your description the lens housing has probably been damaged, and possibly other parts. Sony supports their products for so long and will not repair, because the camera is 11 years old and the cost to repair could be equal to a new one, I would recommend replacing it.
Posted on Apr 05, 2011
0 characters
1 Points
Disc Error
Repair will probably run from $180. to over $250. You can try to gently clean the lens with a Q-tip and cleaner.
This is a common problem with the Mavicas....The 400 and 500 models seem to last longer,but in the end..Sony has created another camera that despite it's price is a 'throw away camera" (just like the one's that used floppies)
Mar 17, 2008 | Sony Mavica MVC-CD300 Digital Camera
Getting pictures loaded from mavica mvc cd300 camera to computer
Jan 23, 2008 | Sony Mavica MVC-CD300 Digital Camera
Sony Mavica FD83 Diisk error C:13:01
I've got the same problem with a Sony Mavica FD83 floppy disc camera. The screen says DISK ERROR C:13:01
Any idea of what may be wrong ? I think this is a common problem with these cameras....but it's priobably an easy fix. Can you help me ?
BERNIE
Jan 22, 2008 | Sony Mavica MVC-FD83 Digital Camera
Sony Mavica MVC-73
Aug 28, 2006 | Sony Mavica MVC-FD73 Digital Camera
Cd300 resetting default setting
Okie-tex, Why yes you can reset your cd300 back to the factory settings. On the bottom of the camera underneath the on and off button for your LCD is a little hole and it says reset next to it. Insert a straight pin into that hole and it will reset everything back to factory settings. Fellow Texan
Sep 13, 2005 | Sony Mavica MVC-CD300 Digital Camera
Mavica cd300
Sep 12, 2005 | Sony Mavica MVC-CD300 Digital Camera
MHG07A wide lens, cd300, best settings?
I don't have that camera, but try Macro mode instead of Conversions Lens in setup. If the camera focuses (at Wide setting), then you should be able to get down into the wider apertures.
Not happy with my CD300
The problem is in your ISO. The camera has a terrible noise problem at anything over 100 ISO. I set my camera to 100 even when shooting in auto, and never use any other ISO setting - the results are just not worth it. Hang in there. The camera is awesome and you will make friends with it. The settings are really not that complicated once you get used to them. Just decrease your shutter speed and increase your aperature (lowest number) when in low light conditions and watch the LCD until it looks good (you might have to half press the shutter to get a preview), until you get a bettter grasp of what those adjustments are doing for you. Good luck, Cindy
Oudoors with my Mavica....help!!!!
While it is no help for those with other cameras, Sony has fixed the problem with the FD91 which has a viewfinder that is not bothered by sunlight. The F505 LCD evidently works good in sunlight.
Sep 08, 2005 | Sony Mavica MVC-CD300 Digital Camera
IPhoto doesn't recognize Sony MVC CD300
Even though Sony Mavica digital cameras are listed as compatible with iPhoto, the camera has to be set to Picture-Transfer-Protocol (PTP) before you can download. In addition, you will need to open Image Capture in the Applications folder. As soon as these steps are taken, the camera is recognized by iPhoto and all photos downloaded into Image Capture.
Sony Mavica MVC-CD300 Digital Camera Logo
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
